sodamo
Super Star Member
- Joined
- May 20, 2004
- Messages
- 18,473
- Location
- Big Island, HI
- Tractor
- Bobcat CT4545 LS XR4140H (Mine) BX2380 (wife’s)
Worked on the water system today. We have a rain water catchment system for those needing a memory jog
. We catch the rain from the main house and garage roofs which is filtered into 4 poly tanks, 4K gallons each. Then filtered thru a 20-5 micron sediment filter, 5 micron charcoal filter, 1 micron sediment filter, UV light and into the house. So today I purged the system from the pump, disinfected the filter system and replaced the filters. Disinfected by running bleach thru the system via the empty filter bodies. That means opening all valves until I could smell the chlorine, close them and then return to each to run until back to running non treated water. That was 4 toilets to flush, 10 sinks with both hot and cold, 4 showers, 2 tubs. I didn’t even attempt the dish washer or clothes washer or outside spigots. Too many valves
Thought I had another test kit around, but not finding it.
