CK2610 Maintenance
/ CK2610 Maintenance #1
chuckles148
NB, Canada
Kioti CK2610
So I'm a little confused on the maintenance. The dealer is telling me different than the book.
I am at about 160 hours last services was 50 hours.
When do I need to change the engine oil? Transmission oil, etc.
What does "Check" vs "Replace" mean?
Thanks for your advice
/ CK2610 Maintenance #2
Its says change engine oil and filter every 250 hours , check means look at replace means change:)
That's what I thought too but the dealer said change the oil at 150h. Basically 100h after the initial oil change at 50
/ CK2610 Maintenance #4
Some change the oil every year if the don't put on the hours I go every 200 hours on engine oil and filter , and I keep them inside the barn out of the weather
So when you check the filter what are you looking for. I mean other than leaks there isn't really much to check is there. It's the same as a car more or less isn't it.
/ CK2610 Maintenance #6
Same as a car just check oil level on the dip stick and the filter for leaks , sometimes the get hit with branches etc and might leak ( others have posted it :( )
Second question when I do change the oil. The manual tells me 3 different grades of oil. Which one do I use?
/ CK2610 Maintenance #8
I would split the difference and go for the middle one.
I would use what I've been using for years. Rotella T-6 5w-40
/ CK2610 Maintenance #9
You can use Mobil delvac 15/40 or Shell Rotella T6 Full Synthetic Heavy Duty Engine Oil ,It depends on how much money you want to spend and how cold it gets up there If you use it to plow snow synthetic will flow better in the cold easy starting
The winters get cold, -10 to -30C. This year we have a pile of snow so I'll take your advise and go synthetic. It is not synthetic now is there any issues switching?
/ CK2610 Maintenance #11
No just don't mix the oils,Just change oil and filter and if you have to add oil use the same oil
/ CK2610 Maintenance #12
I second the Rotella T-6 5w40. I've really learned to appreciate it this past winter, and I'm sure the tractor does too. I think Delo makes a 5w40 as well. Either would be an excellent choice for your area in Canada.
Quick Attach Snow Push (A66408)
Quick Attach Snow...
Snow Plow & Salt Spreader (A62613)
Snow Plow & Salt...
6ft. Telehandler Forks (A65640)
6ft. Telehandler...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
