BX2380 Throttle Lever Slips
/ BX2380 Throttle Lever Slips #1
deathtoblackberries
Gold Member
Battle Ground, WA
Kubota BX2380
Is there a way to tighten the throttle lever so it doesn't slip? I push it to 2,500 and it slips back to 1800, I can push the throttle lever and watch it move back all by itself. Eventually after I mash it up enough times it stays put but its annoying me.
/ BX2380 Throttle Lever Slips #2
I do believe it can be adjusted, take the screen below the steering wheel off and look up under the dash, there is a nut on the throttle lever that can adjust the friction to hold the lever at what ever position you select.
/ BX2380 Throttle Lever Slips #3
I had the same problem, and this was the exact fix I did to mine.
/ BX2380 Throttle Lever Slips #4
Same problem last year. Suppose to have a double nut on bottom of the throttle arm. The first one had vibrated off. Got lucky it was trapped by the screen under the steering wheel. I have bought locknuts to replace the standard flange nuts that come from the factory.
/ BX2380 Throttle Lever Slips #5
Mine was doing that. Both nuts were present, however the both nuts kept loosening in unison no matter how I adjusted them. I ended up installing a nyloc on the bottom and it has been perfect so far.
/ BX2380 Throttle Lever Slips #6
Love your handle! Haven't had your issue but I did stay at a Holiday Inn. Does make me curious and will look at the linkage on my BX.
Battleground... I had a long distance ( 3hr drive) just after high school, love affair with a girl (she was a cheerleader) in Battleground back in the day. long story... well not long enough if I would have had it my way.
/ BX2380 Throttle Lever Slips #7
One of the many problems I had with the JD 1025R.
Ralph
LOL everyone who lives in Washington/Oregon gets what my handle is about.
207271 (A52708)
207271 (A52708)
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Wooden Wagon Wheel Table (A61569)
Wooden Wagon Wheel...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lift (A61568)
2010 Ari Hetra...
