Oil & Fuel Wix Hyd and Fuel filters for CK4010 HST
   / Wix Hyd and Fuel filters for CK4010 HST #1
neopheous
Ohio
Kioti CK4010
Anyone have the Wix cross reference numbers for the following:
They are having their seasonal sale thru the 24th so you can really save....
Hyd Filter - T2185-38031
Fuel Filter - F6800-16411
I believe I have the correct ones for the following:
Air Filter - E7230-11081 Wix - 46489 -Outer 46490 Inner
Oil filter - E6201-32443 Wix - 51324 or 51381 (shorter)
HST Filter - T5855-46531 Wix - 51621
I believe the Hydraulic to be a Wix 57098 but I can not confirm this... have searched the forums here and all the cross reference sites but was unable to find them. Thx.
   / Wix Hyd and Fuel filters for CK4010 HST #2
Question,are the wix filters that much cheaper than kioti filters?
   / Wix Hyd and Fuel filters for CK4010 HST #3
I think its always good to know your alternatives. Dealers come and go, availability can vary, you may have a large fleet and want to stick with one filter distributor. An alternative filter distributor may be right down the road providing a large convenience factor. There are many good reasons.
Warranty issues regarding incorrect filter usage is certainly a possibility, and certainly happens with catastrophic equipment damage as a result, but this should be of little concern to a well studied equipment owner using a correctly rated, suitable cross reference.
   / Wix Hyd and Fuel filters for CK4010 HST #4
Kioti filters from my dealer are within $1 of Napa or Parts depot or Lordco.
   / Wix Hyd and Fuel filters for CK4010 HST #5
Well, I would think... I haven't tried the dealer yet, but here is the prices I was just quoted for these filters from the local NAPA store, so maybe someone can tell me if these are good prices or not....
Oil filter - E6201-32443 Wix - 51324 (longer) or 51381 (shorter) Price: $4.70
HST Filter - T5855-46531 Wix - 51621 Price: $16.55
Hyd Filter - T2185-38031 Wix - 57098?? (not sure if this is correct filter)
Fuel Filter - F6800-16411 ????
Air Filter - E7230-11081 Wix - 46489 - (Outer) 46490 (Inner) Price (Outer): $17.65
   / Wix Hyd and Fuel filters for CK4010 HST #7
The air filter is a Donaldson. One cannot get better then that. Why get a wix?
If anything go to Donaldson website and x-ref. for your tractor and buy a couple.
Donaldson make the filters for the M1 Abrams tank.
They make replacements and or reusable one depending on application.
The Kioti filter casing may be thicker then the aftermarket per one video where a homesteader cut the cases open to review the internal differences in material and quality.
Why risk a few dollars for such a large investment of a working tool one relies on?
If you support your dealer by using factory filters you may get way much better support on many level. But should you have any issues in the future and have wix filter who knows how that will go over. All that said, if machine is still under warranty.
Anyways your $$ ..... good luck
Well.... been there done that.... unless I am looking it up on the wrong site I have tried both Donaldson and Baldwin filter cross reference sites and both said the part numbers I have from Kioti are not found... do you have the website? This is the one I used: Donaldson Filter Cross Reference and Application Search
The part numbers I am using are as follows: (even tried them w/o the dash....)
Just tried another Donaldson site and same results..... seems strange if Donaldson is making these filters they don't list them.... plus when I tried by manufacturer it didn't even have Kioti on their site... they did have Daedong, but the only tractors listed were DK series, and when I selected the DK35 it cam back with no results.
   / Wix Hyd and Fuel filters for CK4010 HST #10
Sometimes the numbers just don't cross over:confused3: How old is the tractor?
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2018 MACK CHU613 DAYCAB (A55745)
2018 MACK CHU613...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2017 John Deere 6120E (A53317)
2017 John Deere...
Mini John Deere Truck (A55853)
Mini John Deere...
