Disc or tiller?
/ Disc or tiller? #1
TimberHole
Missouri
JD9504WD w/ 75 Loader, JD345, Bobcat S150
I want put in some food plots in the river bottoms. I don't want to turn the soil very deep as I think it would just promote erosion. A 5' tiller starts at about $1,500.00 and a 6.5' disc starts at about $800.00. Any suggestions on which would be best for this work? I feel like a disc is adequate but was thinking I could also use the tiller for gardening and also to loosen the soil and then move with my FEL. I realize this isn't the most efficient way to move dirt but would at least let me do some small projects. Thoughts?
Tractor is a 30 hp with MFWD, FEL and power steering.
/ Disc or tiller? #2
A tiller is great for breaking up new ground and also great for loosening ground for easy pickup with your FEL.
/ Disc or tiller? #3
It seems you have already derived your answer. The disc should perform the task to address the food plots. The tiller would provide additional benefit with regard to proposed garden. A roller would be helpful to set the seed at food plots, subsequent to disking. Cultipacker would set seed as well, however more expensive option.
/ Disc or tiller?
Point taken but to clarify I've never used either implement. I guess my question was whether folks found enough extra value in the tiller to justify the cost difference.
/ Disc or tiller? #5
If you are doing large food plots, go with a disk. They work much, much faster than a tiller. Tillers are slow. If you want to finely prepare soil for a garden, the tiller easily wins. We do 20 ac of food plots every fall and we can easily disk the 20 ac with 2 runs in about 6 hrs with a 8' disk and 65hp tractor. It takes me 20 min to till my 5000 sq ft garden. Of course, we are looking for different results, but you can run fast with a properly matched disk.
/ Disc or tiller? #6
A light weight $800 disc is not gonna do well if the soil is packed, or if there is vegetation.
If the soil is already bare....and somewhat soft (like you could dig pretty easy with a shovel)....then a disc will be fine, and likely faster.
But a light disc won't cut through the vegetation or hard pack worth a darn
/ Disc or tiller? #7
I assume you are looking a 4-axle (in an X-configuration) tandem disc that attaches to your 3 point hitch. Mow the food plot as short as you can, add a few hundred pounds of extra weight to that disc, and you should be able punch through the undisturbed sod.
If your garden is small (1/2 acre are less), get yourself a good rear-tine walk-behind rototiller. Cost:$600-700.
Good luck
/ Disc or tiller? #8
Disc on large Ag type tractors work well;not so much with the smaller tractors and disc that they can pull.Virgin ground;plow and roto-till;established plots roto-till should only should work.
A lot depends on soil types also;but for us it would take multiple passes with a disc where one pass with the tiller works.
/ Disc or tiller? #9
I've owned and used both on garden plots, with two different 45hp tractors. My experience has been exactly as above. The disc is almost useless on sod or vegetated, undisturbed ground. You might get something OK after 6-10 passes, but will have spent a ton of time and probably compacted the soil below 4-6" in doing so. A good rototiller will break sod in one pass, and make a nice seedbed in two passes. The big discs used by professional farmers have four to eight times as much weight per disc wheel as anything readily available for small tractors, so they work much more effectively.
Soil type matters. A dry, sandy soil with thin vegetation will let a small disc work pretty well. Damp clay soil with healthy vegetation will keep it from penetrating.
/ Disc or tiller? #11
Totally
Relative to soil types and vegetation mat, a disk is not going to work well. Plow then disc or tiller will cut through making a much better finish product.
/ Disc or tiller?
I've found a store with 60" King Kutter on sale. It's a couple of hours away but I'm headed there in the morning. If all goes well I'll have a tiller before noon tomorrow. I don't usually buy new but I can't find a decent used disc or tiller. When I do see one they want new price.
/ Disc or tiller? #13
I'm in the same boat. I've been looking for a tiller and I've decided on the 5 foot king kutter from Rural King.
/ Disc or tiller? #14
I've been happy with my 60" King Kutter tiller. Fit my L3200 well, but is ok on my 72" track L4060 as well (wish it was 72").
If you are doing under a few acres, a tiller is the way to go. So much more maneuverable.
/ Disc or tiller?
I picked up a King Kutter 5' tiller yesterday. Atwoods had it on sale for $1,349.00 plus a 10% rebate which is a in store credit. Seemed like a good deal compared to the other prices I found. I didn't have much time to play with it but I did put it in the ground a short bit and it seemed impressive to me. I think it will do everything I need to do.
/ Disc or tiller? #16
With your other usage suggestions I would go with the tiller. I bought my first last year, after 40 years of farming with discs. Mine is a 6', 54 tine I bought at TSC and run it on my Ford 3000 which is under 40 hp. It's a super one pass surface/2" deep mulcher; an all in one pass (plus a following with a spike toothed harrow for max smoothness of the surface). HP is no big deal as you usually run slow so there are plenty of revolutions per foot of forward movement.....hp is torque (higher hp tractor) x rpms......got the rpms moving slow so you don't need the torque.
However, before using on long stem plants, I'd mow it with a shredder. You will get much better performance out of your tiller and not have to worry about vines and long stems getting wrapped around the shaft, causing you to have to stop and clean things out. Makes for a much smoother finish too....helps to prevent clumping and clumping of long stems makes wads under your spike tooth harrow and just not as clean a job when finished......I like my field to look like my lawn when finished....minus the grass of course.
/ Disc or tiller? #17
You got one HE11 of a deal on that KK tiller !
/ Disc or tiller? #18
I'd get a disk and use the money you saved to get a sprayer. If it's bottom ground it should be flat and you shouldn't have to worry about erosion unless the river/creek gets out.
Id spray whats there, disk, and then spray again. Pretty much any food plot seed can be broadcast. If it's beans I would broadcast and then lightly disk it again. If it's radishes, turnips, clover, etc Id just broadcast and then if you have a cultipacker use it, if not it should still do okay.
/ Disc or tiller? #19
We converted about 10 acres from a corn field to pasture grass for the horse. We mowed short with bush hog, sprayed with round up and then tilled, then I hit with a drag harrow. Going slow I could get it nice in one pass. I could go faster and need 2 passes. Ultimately it was about the same amount of time. Then I broad cast the grass seed. That was last fall. Now that spring has sprung we have wonderful pasture.
No it is not as smooth as I would want my lawn, but it will work for the horses.
For what you want that tiller will do the job well.
Now that I have the tiller I am going to do like you suggested. I want to put in an extension of my gravel drive. I need to remove 4 inches or so of topsoil. I will hit it with the tiller to make pulling it out with the FEL that much easier.
/ Disc or tiller? #20
Tiller is the way to go. I bought my KK used and do my garden with it, leveled and put in a lawn with it and use it as 750lbs of ballast for FEL jobs. Very glad I have it. Turns sod into garden soil in 2 passes.
KING 4R CHISEL RIPPER BEDDER (A63291)
KING 4R CHISEL...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
