What is this out of?
/ What is this out of? #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
Reworking a wood line need to the drive and unearthed thede things. What is that out of? 20180317_103847.jpg
/ What is this out of? #2
My long lost flux capacitor!
/ What is this out of? #3
Looks like clutch plates out of a automatic transmission.
/ What is this out of? #4
Yep a big old machine or possibly a big logging winch- although I’ve never been inside a big logging winch so that’s a swag.
/ What is this out of? #8
they look like skidder brakes or dozer brakes as previously mentioned.
/ What is this out of? #9
there some type of Wet friction plates, for either brakes, or power shift transmissions, or automatic transmission, (wet means they run in a hydraulic or transmission oil)
steels or disks of steel with teeth on them will fit between them and then a hydraulic piston will push against them putting pressure, and locking them together if enough pressure is applied, thus a clutch,
similar action is used as brakes,
the plates teeth lock in to one side, either the drum or the shaft and the steels lock in to to apposite,
and a piston when applied presses against them locking the shaft to the drum,
on an automatic transmission / power shift transmission, this is how the gear range is changed,
on brakes it locks a moving part to a stationary part, on clutches like in a dozer, it locks up the drive axles or releases them,
On some clutches there are planetary gears and they use a brake band, that stops the drumm from spinned and forces the rotary power to the out going shaft, in some transmission there is a combination of clutches that work the inside of the drum and some times the outside of the drum with a band, and depending on what clutches lock up is how the transmission shifts, or transmits power through the gears, to the drive axles,
/ What is this out of? #12
It looks like the original Spiroscope toy, likely in an early production phase before they started making them out of plastic.
/ What is this out of? #13
Nearly 30 years ago I bought an HD 3 Allis Chalmers dozer that had been sitting quite a while and I ended up having to replace the steering clutches on it. They looked an awful lot like what you have found as best as I remember. That old tractor was built in the early 60's and parts were getting a little hard to find and pretty pricey. It ran great though after rebuilding the clutches, engine,and injection pump.
/ What is this out of? #15
Maybe they fell off a pallet that was in the field....
:confused3::dance1::laughing::laughing::laughing:
Later,
Dan
