Overtaxed
New Member
- Joined
- Aug 2, 2016
- Messages
- 371
- Location
- Gaffney, SC
- Tractor
- Kioti NX6010, JD 2720 w/46BH, Honda Pioneer 1000
I have a 16" Everything Attachments single bottom plow that I'm pulling through some rough stuff (clay, unbroken ground) and I can't keep a shear pin alive for more than a few runs through the field. My tractor is 60HP, 4WD (although I've been in 2WD trying to "spin" before I break it, doesn't work), about 8000 lbs (Kioti NX6010, 4WD, HST, loaded ag tires and FEL). I have a lot of other ground engaging gear, including a big box blade that will stop the tractor with the rippers down, no problem, but the plow, it seems to break the pin when I look at it wrong. Compounding matters, the rotation of the plow when the pin breaks is incredibly stiff, so, I have to beat it with a sledge to get it back into position. As you can imagine, breaking the pin is coupled by a string of cursing, because I know it's 10 minutes of pounding to get another stupid pin in.
A few questions; should I just go to a harder bolt? What's the downside; obviously the tractor can take the stress, the box blade, as I said before, hooks up the same way and will stop it dead if I dig in deep. So I'm not worried about the harder pin breaking the 3pt (but, maybe I should be?). Weld the plow up and just remove the "release" entirely? I have a subsoiler and potato plow without a pin and never have problems with them. Drill out the hole and put in a bigger bolt? New plow (hope this isn't the answer!).
Thanks for the help!
