Good morning!!!!
   / Good morning!!!! #72,351
At four per month won’t they get stale, rancid? I’m looking for a source of very small quantities. Like a place selling them 4 at a time?
I wonder if it matters how they’re processed? Roasted, dry roasted, salted, not salted?
I too am interested.
Our house is a strange design, but "passive solar oriented" to the site that seems to work...... sometimes. The first generation "high tech" "triple paned" windows that replaced the original windows around here work; but need to be replaced. Solar gain as a contributing heat source works both ways.
   / Good morning!!!! #72,352
Just ordered 5 pounds from Blain's Farm and Fleet. Should last a while :)
Rick the nuts in the study were raw.
A 1-oz. serving of Brazil nuts -- consists of only six kernels. A serving contains 190 calories, 4 g of protein, 19 g of total fat with 4 g of saturated fat, 780 percent of the daily recommended intake of selenium and 25 percent of the daily intake of magnesium and copper.
Since the research was only done with 4 nuts you can only have 4 a month - no more, no less.
According to my calculations you have enough for one person for a decade.:eek:
1 oz = 6 nuts
5 lb = 80 oz
80 oz = 480 nuts
480 nuts /4per month = 120 months = 10 years
Remember treat this food as a medicine, more is not better and you could get into side effects.
   / Good morning!!!! #72,353
As you age you will find it harder to live in that low temperature.
Maybe, but I'm 68 now...seems to still be OK.
We do turn it up a few degrees (65-66) on those cold damp days though.
We had a stretch before Christmas where the early morning (0330-0500) temperatures were well below zero (couple of those days were minus 25 or so). Those were tough...but a week or so back, I was at a hotel in Hartford CT...stepped outside at 0630 or so wearing a tee shirt and jeans (smoking a cigarette)...talking to a guy from Georgia (also smoking) bundled up. I guess the temperature was in the low 30's. It all depends what one is used to.
   / Good morning!!!! #72,354
Wife has the upstairs at 65, 66 downstairs.
Nothing like nutty research....
Daylight savings time, is like having a blanket that won't cover your feet, so you cut a foot off the top and sew it on the bottom so it will.
   / Good morning!!!! #72,355
1 oz = 6 nuts
5 lb = 80 oz
80 oz = 480 nuts
Thanks for the clarification Don. I’m not a fan of Brazil nuts or raw nuts in general but .... if I only need to consume 4-6 (1 oz.) per month ... I’m in.
Wouldn’t raw nuts go bad after a long period of time? I’m more inclined to getting smaller, fresher, quantities.
Thanks for your leadership on helping us with out health?
   / Good morning!!!! #72,356
Spring Forward ..... Fall Back.
Don’t forget forget your clocks tonight....... where applicable.
   / Good morning!!!! #72,357
Not 4-6. Only 4 nuts per month.
Four Nuts Once a Month | NutritionFacts.org
As the video points out it was not sponsored by the Brazil nut companies which is a plus, but it was on a small group of people. It needs to be tested on a larger group and see if the results are the same. Don't overdose on these little selenium bombs, only 4.
I have had some raw Brazil nuts in my pantry in a resealable container for over 8 months and they have not gone rancid.
Clocks are adjusted, now if we can just get DST to stop that would be a good thing.
   / Good morning!!!! #72,359
Yesterday, I put new pulleys, 1 new tensioner, and both serpentine belts on the Yukon 5.3L Also, Oil and filter change. Mobil 1 extended life and Mobil 1 filter.
Don, Do you need to eat the selenium bombs all at once? Or can you do once a week for a cumulative effect? Only raw counts?
Hot down here today. A/C on. 76 inside,
Planted 2 more cherry tomatoes, "Grape" cherry tomatoes this time. Also planted some cucumber and cantaloupe seeds. Both types of seeds look remarkably the same... Still need to get the garden bush green beans in...Went and bought some water soluble fertilizer and a 1.5 gallon plastic watering bucket with a sprinkler head. Onions, spinach, and garlic are doing great so far.
   / Good morning!!!! #72,360
Ok, good. I misread your prior post and thought you were saying 1 oz.
I agree on DST! It has long outlived it original purpose.
Daylight saving time - Wikipedia
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
New Holland TV145 4wd Tractor (A56436)
New Holland TV145...
2019 GALYEAN...
40' 1 Trip Shipping Container (A59814)
40' 1 Trip...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
