Kubota L2800, grader scraper size
   / Kubota L2800, grader scraper size
Yes I realize the weight aspect but I'm not buying a new tractor anytime soon. The 3 I have will have to last me the rest of my life unless something catastrophic happens to one of them.
   / Kubota L2800, grader scraper size #12
I think you would be better served by using the the 60" one. 5 feet will cover your tracks and will actually put more weight on the ground.
The most weight on these units are the sides and 3ph... the wider you go the less pressure per inch of blade you'll get. Just divide the weight by the width, easy math. Beside, shorter ones also just happen to be cheaper... :2cents:
   / Kubota L2800, grader scraper size #13
I would go with the heaviest 5' blade I could fined. I would definitely go with nothing wider than 6' for your L2800, should you decide to go wider than 5'.
Most back blades I have seen, you get what you pay for. HD blades are well worth the extra bucks.
   / Kubota L2800, grader scraper size #17
5 foot = 8.9 lbs per inch
6 foot = 8.3 lbs per inch
7 foot = 7.7 lbs per inch
8 foot = 7.4 lbs per inch
Just driving home the point, bigger is not always better (or heavier)...
   / Kubota L2800, grader scraper size #18
I got the scarifies and the ability to go in reverse in mine....very very worthwhile options....especially the scarifers....I use them often on my aweful rutted out dirt hill road.
Update: I ended up with a 5' Yanmar (rebranded Woods). I think I made the right decision getting the 5'. Spent some time with it today and was shocked at how well it works over the box blade I was using.
2020 Hino 195 20ft. Electric Box Truck (A55852)
2020 Hino 195...
(UNUSED) PROTECTA PRO-LINE (A57192)
(UNUSED) PROTECTA...
2019 BOBCAT T450 SKID STEER (A52707)
2019 BOBCAT T450...
UNUSED IRANCH IRTPL 10,000# TWO POST LIFT (RED) (A57193)
UNUSED IRANCH...
Drive Over Scales w/ Monitors (A53317)
Drive Over Scales...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
