Backhoe sick T3-15
/ sick T3-15 #1
jeffax06
big sandy, tn
T3 Terramite backhoe
I am rebuilding a T3-15 and like a dummy I loaned it out to my bother...well the hydrostatic rear end, pinion and gear are chewed up. I contacted Conequip. to see if they could help me, but its still up in the air because the T3 is so old...I am asking if anyone has any ideal for a rear end or parts I might track down..thanks jeff
/ sick T3-15 #2
Jeff do you know if the 3-15 shares the same rear end as a terramite 4? If it does I can get you some information on it
/ sick T3-15
You know, I can't honestly answer that because I have never seen a T4 terramite. heck..I never saw a T3 until I bought this one off the side of the road....but I would assume that if its hydrostatic drive rear end and being the next type they came out with...well I would think they would match...I don't know what year they went to shaft drive, maybe T7....? but think you and yes if it hydrostatic drive ...please let me know...I am stumped on this hitting brick walls at every turn so far....1167bp thank you for responding either way..
/ sick T3-15 #4
/ sick T3-15
Thank you....1167bp I will try to use this information in ordering the parts I need...of course that is if they still have them.... think positive right !! this is it...same rearend..I'll get on it today!!
/ sick T3-15 #6
Glad to hear it's the same rear end.. you may be able to source the parts elsewhere too. They will probably just not be able to search "terramite" to find them
/ sick T3-15
well after a closer look, this rear end is a shaft driven not a hydrostatic drive...but the pinion and gear appear to be the same..I sent a copy of the drawing to equipment/terramite and I'm waiting to see what they say....I have the number off the gears, you would think that's all I needed
/ sick T3-15 #8
The Dana 44 diff is popular amongst most Terramite models. The power of the units are in the pumps and their abilities. From around 2013 those diff's were changed. Spares should not be difficult to get.
TerraQuip Construction Products, Inc.
600 Goff Mountain Rd
Cross Lanes, WV 25313
800-428-3772
304-776-4231
304-776-4845 (Fax)
/ sick T3-15 #9
800-428-3772
304-776-4231
304-776-4845 (Fax)
/ sick T3-15
I have tried eastcoast gear, westcoast pinion, conequip, and dana who refered me to shafer drive who has yet to respond...etc..so if you know something I don't please let me know. I am going to start calling junkyard next. info on pinion is ( 500A14 60 12 V1W173) gear is (02 0598 DANA D 840045 P8L137 60 12) if anyone can help and I will call terraquip too. might as well...thank you TractormanSA...south Africa....really.
/ sick T3-15 #11
If you call Terramite the part numbers you require will be.
1. Part Number 64004 Gear and Pinion ***'y-Drive
2. Part Number 55240 Pinion-Differential
3. Part Number 55400 Gear-Differential
4. Part Number 55410 Shaft-Differential
These are the gears you will require to repair your Differential.
Yes I am really from South Africa......
Terramite machines have a footprint in Africa.....
I currently take care of the Product Support for Terramite in Africa.
Please let me know if their is any other information that I can assist with.
/ sick T3-15
thank you TractormanSA, I tried to call them before and they said they didn't handle T3's . I will try it with these part number. if I can get them on the phone that is...I'll try again today. and get back to you. South Africa, that's pretty cool to see this forum stretch that far. 8:10am
/ sick T3-15 #13
Well when I start reading this I realised you'll not getting assistance so hence I joined the forum. Thank God for technology. My email is romano@phillipssa.co.za drop me a mail and I will send you all the information on a compatible diff. Whatsapp +27713001719.
/ sick T3-15
I am currently looking for a supstitute hydrostatic transaxle rear end to replace mine on the sick-t3. john deer 400 has one that looks like it might hold up to the weight of the backhoe, just don't know if I can make it work?? does anyone have any ideals ?? thanks jeff
/ sick T3-15
I am happy to report that I have solved the mystery with my sick-T3. the hydrostatic trans axle is not a terrmite drive, but a 300 john deer someone mounted on it years ago. I didn't know one way or another if it was suppose to be a shaft drive or hydro drive, no one told me other wise. I found out buy luck while on ebay. the 400 looked close, so I backed up to a 300 and a 316 and bam!! their it was. I bought one out in N.C. a 9.5 hour drive, but what the heck. the parts are not made anymore so I bought the rear drive transaxle complete. I will switch rear ends and sell it...thanks again to those who tried to help me in this matter. jeff
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A64556)
2016 Peterbilt 579...
2022 EZ-GO ELITE...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
2013 Toro Groundsmaster 3280D 72in. Commercial Riding Mower (A64194)
2013 Toro...
