Same R3's or something new?
/ Same R3's or something new? #1
mercdv
South Carolina
John Deere 2305
Okay, I hate to admit it but I can't make a freaking decision. I just don't have experience using any other tires so I kind of wanted to pitch this out there and see what people think. I have JD 2305 that I bought 9 years ago and the tires need to be replaced. I bought it with R3 tires because I didn't want to tear up the lawn. The current setup is Carlisle Multi-Trac C/S 18x8.50-10 4-ply on the front and 26x12.00-12 4-ply on the rear. I mainly mow, move heavy items, and dig with the backhoe. I've been pretty pleased with the tires so far but I do have a couple small steep hills (30%+ grade) that cause some problems. We have some wooded portions on our property that are all on hills and have heavy thick leaf coverage on the ground. I haven't ventured in those areas yet but I plan on doing that this year to clear some of it. It also has a lot of thorns in that area. I thought about moving to R4's but I heard they can lead to sliding sideways on wet/sloped terrain when traveling across the grade. Part of the area I mow requires my to travel perpendicular to to the grade and the Multi-Trac have worked pretty well. The tractor gets a little light on me so I know I'm pushing it and the grip needs to be good. I also lift close to the max rating for this tractor from time to time (not often). I'm not even sure I should be doing that with the tires because I haven't calculated the static load on the front tires. The do get squished pretty good.
I guess what I'm asking is should I stay with the Multi-Trac C/S or move to something else? Any suggestions on a good tire if I should switch? I have no experience with another type of tire because I worked on a golf course for years and we just used turf tires there too. I want to make sure I have enough grip not to get stuck on the hills in the loose leaves. The grade on this portion of the property runs from about 10%-20% but it hasn't been cleared before so the leaves are thick and soil is loose.
/ Same R3's or something new? #3
/ Same R3's or something new? #4
For all of the bashing that R4 tires get, they have been great performers for me. I have never had issues with them sliding sideways, and they will be the most thorn proof, short of foam filled.
Thanks for the feedback...I'm now waffling more between the R3's and R4's. I guess I'll go down to the local shop and see if they will let me take a lap around the parking lot with a similar size tractor with R4's. Before I was still leaning heavily towards the R3's but now I'm a 50/50 split on the R4's.
/ Same R3's or something new? #6
Do R3 and R4 use the same rim?I would think new R3's would out grip R4's on a side hill.
/ Same R3's or something new? #7
See how heavy of a ply rating you can get with R3's... I would see if 6 or 8 ply is possible.
The R-4's should fit my rims according to the specs. I'm starting to lean back towards the R3's. I wanted to get a more aggressive R3 pattern but if I do I can't find anything greater than 4 ply. :(
After some way too late night research last night, I did find that I could get my current tires in 6 ply with a heavier load rating on the front tires. It comes in at about 225 lbs more per front tire. Which puts it on par with all the R-4's I have found for lifting capacity.
Gah....wish tires weren't so expensive because being stuck with them for a long time just makes this decision that much harder for me.
/ Same R3's or something new? #9
I understand your cost problem and being stuck with a set of tires for as long as it takes to wear them out, and it is almost like trying to decide between a Good Looking Women and a not so good looking friend, to consider getting married to.
Since you are still in the dating mode, and haven't gotten married yet, remember your friends. One that has been by you when you needed a job done, and performed as requested doesn't need to be cast away for the new version.
However, there may be another choice. Do you have any nearby tractor owners with the style tire you are considering? I would not have a problem letting someone borrow my tires for a weekend if they swapped them out (with $ equal tires) to give them a try. Or if they hauled my tractor (same size as theirs) up to their place just to see if the tires made a difference. Most tractor people understand what you are up against and would like to help.
Take off's...consider calling around and seeing if you can find a set of take-off's either at a dealer or somewhere on the web. You might be able to save a couple dollars and still get the tires you want, along with a set of rims so that if you just really don't like them, you still have a way (with another large chunk of $) to go back to the other tire you were considering. Buying a slightly used set of the "other" tires might give you some time and the answers you are looking for.
David from jax
/ Same R3's or something new? #10
You don't mention having a FEL. I had a 4010 (2019E by today's nomenclature) with R3s. Then 1025R and 2025R with R4s. The R4s are a lot tougher for using the FEL. Had lots of troubles with the R3s with FEL but they do have better side grip and turning grip. Think with R4s, you need turning brakes to aid the turning, which you don't have.
Ralph
/ Same R3's or something new? #11
Well wish I had your problem.
My 18" R3 turfs are no longer in production (got last pair in Canada) and that with installation set me back close to $900.
They rapidly dry rotted (like after 6 months) and I am now stuck.
Threads have minimal wear but the side walls look like the surface of the moon or mars.
Goodrich, then Firestone now Michelin are of no help. Dealer rep did respond to email but never called back next day as promised. (did 3 email follow ups), guess they simply don't care to take care of a client.
Why then do they post email links? (to look good?)
Had I known of this lack of support I would have simply foamed my old (pre $900. outlay) and have been ahead.
Am I PO'd. yes for sure.
My choices now are to find 18" truck tires that respect front to rear ratios or to foam the Goodrich crappy tires that I laid out $900. hard earned $s for. (and that after taxes)
Am I PO'd? yes!
OK. so I have attempted to get quotes on foaming but so far nobody has come back with a quote.
/ Same R3's or something new? #12
PiLoon, with your back up to the wall, I would get the R2 tires. I see BKT makes them, I have got several pairs of BKT and been very happy with them. If the deep lugs are an issue, supposedly a tire recap shop will have a tool to shave down rubber, so Ive been told.
2015 MACK CHU613 DUMP TRUCK (A60736)
2015 MACK CHU613...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2013 MAXX-D BUMPER PULL TRAILER (A60736)
2013 MAXX-D BUMPER...
2008 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59906)
2008 HINO 268 4X2...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
