grsthegreat
Super Star Member
the lower rpm is for the exercise cycle only. Personally i never set them to quiet mode because the engine only runs at 2400 rpm or so for 5 minutes, and i dont think thats fast or long enough to bake out any moisture in the oil. I let mine run at full 3600 rpm for 5 minutes every week in winter. Ill change it to monthly in summer.How can you go through a major outage w/o a hot tub ? Just upsize the whole thing to 40kw and the relay noise will go away
(Good feedback grs, I'm sure other auto-Generac owners are taking note.......)
With a maintenance run like this one, is the idea to run at reduced speed just to minimize noise ? No power could be delivered to load at low rpm - the voltage would be wrong; or am I missing something about how these recent 22kw are designed ?
Rgds, D.
There is a line of generators called synergy (generac still) that will actually power loads while running at lower rpm for mild loads or full 3600 rpm for heavy loads. They use alot of load shed relays, and personally i wont install them. There too complicated for my old brain. If someone wants one ill refer them to another dealer i know. For people that truly want low noise, kick in another 4 grand and get an 1800 rpm unit with automotive engine. Mine is quieter than a lawn mower. I cant hear it indoors when its running. The closest neighbor is maybe 800 feet away. I doubt he can hear it.
