Glad we have this Isuzu Diesel generator
   / Glad we have this Isuzu Diesel generator #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
High winds. Woke up on generator power. Wife said it came on about 5 am.
It's our 12 kw Isuzu diesel generator from Central Maine Diesel outfit. Our friend, Darryl, ex electrician from Ohio, did the install right at the end of 2012 when I was recovering from CHF. My wife was his chief electrician helper. Had to replace the one circuit breaker box in the house in which were installed some special load sensing breakers like the water heater, clothes dryer, etc. that would only come on if there's room in the generator.
Well, the wife left for the gym late, not very long ago. Driveway alarm just went off. She may have had to come back for some reason.
I cannot get the Miata out of the carriage house to drive it to the extension office to volunteer because those are heavy doors and aren't on the generator. She may have run into a road block somewhere. Earlier, a neighbor reported the road out was blocked by a downed tree.
Here her stomping around upstairs. Y is out without power.
Ralph
   / Glad we have this Isuzu Diesel generator #2
Stay safe! Glad you are wired up. Looks like a nasty storm hitting the east coast today.
   / Glad we have this Isuzu Diesel generator #3
Good deal. I didn't know Isuzu made generators, but I've always heard good thing about their engines.
   / Glad we have this Isuzu Diesel generator #4
can you tell us what kind of breakers/load sensing they are?
The main box and sensor boxes are from GenTran Ovation Series. Darryl had to make lots of calls to their service techs to figure out how to set it up.
We had at least other "whole house" generator outfits come in here for estimates. They came up with needing 30+ hp units, just brute force.
I knew from experience using our 4 kw unit to power a good bit of the house that 12 kw would be enough, if there were gizmos to selectively allow loads. There are from GenTran, hardly anyone else.
Darryl had to wire something in that would shut off the backup coil to the upstairs heat pump to allow it to be on the generator. Since then, we've replaced the upstairs heat pump that works fine without the backup heat coil now and have locked it out with the thermostat (old unit didn't allow this). We've also since then put in ductless heat pump units for the basement. These have no backup electric coil like a regular heat pump does. For those of you who can burn wood, it would have sense to have one of those outdoor wood burning furnaces to provide hot water backup to your main heat pump or even a fireplace insert that heated hot water to provide to the heat pump circulator system.
Ralph
Love this Isuzu diesel engine. It does not clatter and bang like every other (except VW TDIs and probably a lot of modern diesel car and SUV engines now) other older diesel engine. Starts fairly quickly, like about 5 seconds or less after power goes down.
For the first 50 hours before the 1st oil change, the oil on the dipstick was crystal clear. I replaced with Castrol 5w30 oil bought from the VW dealer for TDIs. Still, the dipstick looks like the slightly tan color of the Castrol. Has not turned black yet at all.
Fuel usage is 0.2 gallons/hr. For any years with no power outage, just running 15 minutes ever other week, it uses 2.5 gallons of diesel. I pump some from its 60 gallon tank every so often to put in the tractor, just to get some more out and back into the tank to refresh it. Thank goodness for low sulfur fuel. In the old days, that diesel sitting there would go brown like it did in our 240D when stored 4 years while we were in Singapore before low sulfur diesel came out. The high pressure hydrotreating they do on low sulfur diesel to treat it will remove impurities as is done for all the group III "synthetic" oils out there.
Ralph
   / Glad we have this Isuzu Diesel generator #8
I looked at there web site for a generator before, Not far from me ,Just trying to convince the wife we need to spend that much money:)
   / Glad we have this Isuzu Diesel generator #9
Ralph
Sounds kinda low Ralph if there is any load. Most of the ones I've been looking at are in the 8kw range and use about 1/2 gal/hr or so at 50% load.
The wife today said that it's about the best $15k that we've ever spent. You'll spend a lot more if you go to one of the whole house outfits and may end up with a diesel that'll just sit there and loaf away and get carboned up.
Best bet, if you have NG, is to get one that's on NG. No brainer.
Ralph
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
2019 FORD F550 XL SERVICE TRUCK (A51243)
2019 FORD F550 XL...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
90018 (A48082)
90018 (A48082)
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
