Alternator rebuild needed
   / Alternator rebuild needed #1
def38
woods and mountains of Alabama
M-F 231S
MF 231S, 2003, made in Turkey. Inspecting the alternator shows that the copper slip ring assembly is worn away so badly the phenolic plastic base is showing...in other words, the copper has worn away.
I'm not sure of the alternator manufacturer (possibly Bosch or Marelli?) but local dealer advises that the slip ring p/n 1895348M1 is unavailable with no expected availability date.
Anybody know of an alternate source for the part?
Thanks in advance.
   / Alternator rebuild needed #2
My New Holland Dealer told me what a replacement alternator costs and then suggested that I have it rebuilt at one of the local rebuild shops. I didn't know about them, so he told me where they send their alternators and starters to. When I got there, the guy gave me a price to rebuild it, which was a lot less then my dealer quoted me to buy a new one, but then the guy at the rebuild shop told me that he had another brand that was better then the original one, and that was even cheaper to buy it brand new, then to have my old one rebuilt!!!
Maybe talk to another dealer, or a commercial equipment dealer, and ask if they use a shop to rebuild their stuff? Go in person, and talk face to face. That's how I get the best results.
   / Alternator rebuild needed #3
Definitely do as Eddie said, find a local rebuilder.
They don't always have a big sign out front, because they mostly do wholesale work. But, one may be nearby.
If not, make some calls, and ship it to someone.
Now, that is one fine looking hog...
After further inspection I determined the alternator is a Lucas made in Turkey. I bit the bullet and bought a new one, ~$100.00. A rebuilt would have been about the same. Interesting, I determined that the v belt was OE with a date of 2002. It will be reused.
   / Alternator rebuild needed #6
Hope that works out for you.
Even a Chinese one, is probably better that a Lucas. :D
I grew up riding old Brit motorcycles (Triumphs, BSAs, Nortons, circa 1960) fitted with Lucas electrics. Some of the Lucas systems were + ground, the switches and wiring were pretty much junk and the alternator output was poorly regulated, routinely boiling batteries. Many Brit motorcycles of that era had holes in the battery box and missing paint on the frame area near the battery due to battery boilovers.
The problem with my M-F Lucas alternator is parts availability hence the decision to replace.
Our tractor alternators are subject to a lot of dirt and dust which eventually collects on and in the alternator causing overheating, erosion of the brushes and slip rings as well as possible heat failure of the regulator.
Most alternators for tractors of this size are of low output (50 amps or less) especially diesel powered machines (no ignition system and most of us don't work at night) My M-F will run for hours without any alternator output and I have been refilling the battery with a good battery charger (remember, a descent group 24 maintenance free battery is ~$100.00, a good charger is $35.00). So the M-F electrical system has been running as a total loss system (battery supplies all electrical needs without the benefit of alternator output).
I have decided to add some LED lights in the event that I work at night (when its cooler). And while LEDs draw very little power, the headlights are incandescent and total 110 watts or ~9 amps draw.
More to follow once I have the new alternator in hand and installed....stay tuned...this is gonna be exciting. :reading::
My new alternator is getting close. UPS tracking says it is spending the night in Montgomery, Alabama. I almost soiled myself.
Once I have it in hand, I'll let you all know about the quality just in case there are other alternators out there needing replacement.
Exciting ,eh? Don't go far, get the popcorn ready and stay tuned. :us-alabama: :wave:
UPS says my alternator is in Birmingham...might see it later today.
Aren't you folks excited? I am.:jump:
Well, you all missed it...the new alternator arrived with a celebration and appearance by the Crimson Tide marching band and cheer leaders. Nick Saban couldn't make it.
Alternator is installed and shows 14.18 volts at the battery, engine idling. So, we're done here.
73
def
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
Toro Zero Turn Mower (A50322)
Toro Zero Turn...
2007 MACK GRANITE  TRI-AXLE DUMP TRUCK (A51222)
2007 MACK GRANITE...
