Help on fittings
/ Help on fittings #1
bdw9862
Hutchinson
Yanmar YM146
As I attempt to windup my towable backhoe build I am trying to connect my hydraulic tank to my pump. I need to go from 2 inch NPT (female) on the tank to SAE 12 (female) input on the pump. I have searched the fittings world over and am somewhat close but no cigar.
Any help would be appreciated.
Thanks.
/ Help on fittings #2
Are you wanting to do this with a hose? that might be the easiest?
/ Help on fittings
Yes i do, i need at least inch and a half for proper flow
/ Help on fittings #4
If this is a suction line? see the link below...
1.5" hose may require an adapter because #12 SAE is much smaller than 1.5"...you may have to reduce with NTP bushings to SAE #12...to use 1.5" hose
You can call the folks at the link below and actually talk to a knowledgeable person if you can't find what you need on the site...
Suction Hose Fittings > Discount Hydraulic Hose.com
Good Luck
/ Help on fittings #5
Wow! That's a lot of flow. You can use a 2" NPTM to 1 1/2" NPTF bushing on the tank and use a SAE 12M x 3/4 NPTF Adapter on the pump (your inlet being SAE 12 is smaller than 1 1/2"). Then you can go to a 3/4 NPTM To 1.25 NPTF Adapter and then a 1.25 NPTM to 1.5 NPTF swivel. Then connect the two sides with a hose that has 1.5 NPTM fittings. I just looked at Surplus Center and they only go up to 1" hose fittings and Discount Hydraulics goes up to 1 1/4". Since your pump will be the restriction with the SAE 12 port, you could use either a 1" or 1 1/4" hose (provided that you don't need a larger pump, since you said you needed at least 1 1/2 hose it could be that your pump is undersized).
/ Help on fittings
Actually I need closer to a an inch in line size when i look at my calculations but am having trouble finding those fittings you specified. I have looked all over the net believe it or not.
/ Help on fittings #7
SurplusCenter and Discount Hydraulics (see /Pine's post above) will have most of what you need. For the 2" to 1 1/2" bushing try Eaton-Aeroquip or Parker-Hannifin.
Grainger carries Eaton-Aeroquip. Although a bit pricey at $37 for the bushing.
/ Help on fittings #9
Since it's a suction line you can use common pipe fittings. Any good hardware store will have reducing bushings and hose to pipe fittings. Try Home Depot or Lowes. The SAE 12 fitting they won't have though.
/ Help on fittings #10
Hose size that much bigger than the pump inlet is going to gain you nothing.
What's the gpm of the pump?
/ Help on fittings
Pump is close to 11 gpm on the high side. Calcs call for a little over an inch line. I gotta run a line anyway and probably about a foot only.
/ Help on fittings #12
Go with 1". Reduce your pipe fittings at tank. Getting a -12 orb to pipe to hose Barb should be easy with 1"
Your restriction is still the pump inlet
/ Help on fittings #13
I use The Hose Company they are great to work with and very helpful and the quality is top notch. The sales person I contacted was Justin Robertson their number is 800-698-5754. hydraulichose.com is their website and I think they currently have a 10% off sale.
2017 Freightliner M2 106 Passenger Bus (A66736)
2017 Freightliner...
2006 Ford F-350 4x4 Ext. Cab Reading Service Truck (A66736)
2006 Ford F-350...
2018 Ford F-150 Ext. Cab Pickup Truck (A66736)
2018 Ford F-150...
ROOM WITH MISC ITEMS (A67714)
ROOM WITH MISC...
2020 WEILER S670 FELLER BUNCHER (A65056)
2020 WEILER S670...
2007 OK TRUCK & TRAILER PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
2007 OK TRUCK &...
