Which Tooth Bar should I get for digging into topsoil piles and clearing??
   / Which Tooth Bar should I get for digging into topsoil piles and clearing?? #31
   / Which Tooth Bar should I get for digging into topsoil piles and clearing?? #34
For just digging in dirt, any toothbar will work just fine. Being the cheapskate that I am, I would buy the cheapest one that has replaceable teeth. There is a company that sells one that just has spikes welded to a flat bar, I would stay away from that one. Most of the rest are typical except for the Piranha which is likely the best for cutting saplings, digging out roots etc. since the teeth are short and closer together.
I had to put a tooth bar on my Yanmar 4220 because without the bar, it wouldn't dig at all.
MY B26 has no trouble digging so I never put one on it. I do like not having the tooth bar when back dragging to smooth out dirt and my road since I have not dragging tooth marks.
   / Which Tooth Bar should I get for digging into topsoil piles and clearing?? #35
What were the inside dimensions of the bucket of your CK2610?
Use the link prichard provided. The CK2610 comes in 60" or 66". I just measured mine and it's 66". I'm going to call them tomorrow but it's looking like with the welds on the bottom of the bucket I'd be 65 1/2" inside.
I would but my tractor isn't being delivered until the end of the week and I'd like to put one on order.
   / Which Tooth Bar should I get for digging into topsoil piles and clearing?? #37
Finally got to use my piranha today briefly. I needed a short shallow ditch to get rid of some rainwater. It really dug in. No way I could have done it so easily without it, I've tried.
   / Which Tooth Bar should I get for digging into topsoil piles and clearing?? #38
I'll post to let you know what they tell me tomorrow. You'll need to see if you're getting the 60" or 66" bucket.
   / Which Tooth Bar should I get for digging into topsoil piles and clearing?? #39
Good to hear and thanks for providing the measuring link.
   / Which Tooth Bar should I get for digging into topsoil piles and clearing?? #40
IMHO nothing will beat a true tooth bar for digging in virgin soil or any soil that has imbedded small rocks.
Tip the bucket and back drag and you'll rip out all roots etc.
A real tooth bar will have the teeth extending 3-5" ahead of the cutting edge hence small stones will not deflect and you'll have full bucket loads every time.
Generally a tooth bar sports hardened replaceable teeth that pin on for easy replacement.
While I like the clever idea of the Piranha I would consider it as not a HD digging tool.
A FEL equipped with a bolt on tooth bar becomes a whole new machine.
My CUT now thinks it is a skidsteer or occasionally even doubles as a mini excavator.
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
(APPROX. 20) 4' X...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
