Help finding an appropriately sized FEL or large TLB
   / Help finding an appropriately sized FEL or large TLB #1
s2dm
Member
Carpinteria
Toolcat 5600, Deere 210, Cat 320, Kubota KX080, Kubota KX040, CAT CP433 Compactor, Bobtail dump, cushman truckster
Hi all,
We currently have a kubota kx 040 mini ex and an svl75 track loader on our 10 acre Avo farm. We are deep in the infrastructure phase and have quite a few (1000s) large sandstone boulders to distribute around the property for rock walls as well as ~2500 yards of fill dirt that needs to be shoved around and moved from site to site (not all of the fill is moving, but we need to move a fair bit) as well as general mulch moving, and then double duty as a strong set of forks for offloading mature trees in 6 foot boxes in the 10-15k lbs range.
We got the advice on our first two machines on this forum and they have been awesome, but we've been dropping $300/hr to have a local ex company move this stuff for us with his Deere 544 and it just adds up quick, not to mention being beholden to their schedule.
We'd like to find something that won't get used a ton, but is a very capable lifter (I'm justifying the cost partially by having it replace the chain hoist apparatus we had going in our shop), with atleast a 2 yard bucket and a lifting capacity of 10-15k or more.
Debating about an old cat or deere FEL, in the 544 size range, vs a more mangeable TLB sans backhoe in the deere 710 range. Hoping to spend under 30k and ideally more like 20. Its a machine we'd use for a few hours here and there, so higher hours probably ok. Also don't want to get into something thats a nightmare to maintain.
Any other machines I should be looking at? Don't need a backhoe, but don't mind one. Just really want a bunch of lifting capacity and a large bucket and forks.
   / Help finding an appropriately sized FEL or large TLB #2
How about a wheel loader?
I have seen some that can swap between the bucket and forks.
   / Help finding an appropriately sized FEL or large TLB #3
You are going to have a hard time picking that much with any backhoe especially when you want to take the backhoe off.
Thats what we were thinking, likely a wheel loader, just wanted some help on finding a reliable, smaller one. I really don't want a backhoe attachment if possible.
Hoping to find something without a backhoe, either way, we wouldnt be using the backhoe to lift that much, the capacities mentioned were for the loader portion. We really just need a much more powerful loader with a large bucket, but I could use some help finding the smallest machine that will do the job.
   / Help finding an appropriately sized FEL or large TLB #6
Hi all,
Are you sure about the weight? How many cubic yards of dirt in the 6' box?
This 42', 18.5" DBH oak weighed less than 3,000 pounds:
No, I'm not totally sure. Weights were based on the 544 our contractor was using that was easily picking up things we needed to move. And a skylift which picked up some trees for us that had a 16k capacity.
Its more that we frequently need to move rocks that our SVL won't pick up and we need to move enough dirt that the bucket capacity is getting frustrating on the SVL. So, I don't need to necessarily do everything the 544 can, though if I could find a decently priced machine in that size range I'd jump on it. But I'd just like most manageably sized machine that can push a 2.5-3yard bucket and has a good lifting capacity.
I'm looking at a Deere 710 and a case W20. The Deere would be more versatile but about 2/3 the lifting strength. Comments?
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2017 Nissan Altima 4 door (A56438)
2017 Nissan Altima...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
