Extension cord reels?
/ Extension cord reels?
Wakey- Awesome video. Thanks for sharing. I wish that I knew about this procedure years ago.
I got a Bayco KW-130 at the hardware store in the "Big City."
That knob will un-screw itself the way I reel in line. The place where the knob attaches to the reel is "weak." It needs reinforcement.
And a velcro strap stops the "cord flop."
/ Extension cord reels? #23
A retired Navy guy showed me that trick several years ago, said they did it with cords, hoses and ropes. As he claimed, it kept the a**holes out of the hose when you used it.... His explanation is probably the only reason I've been able to remember it that long.
/ Extension cord reels? #24
I have one of the orange reels but find that the flopping cord end is a PIA. Velcroing it might work. I do find that just wrapping the cord around my hand/elbow works fast and makes a tight bundle. For longer cords, I simply gather up an arm length per wrap and then hang it on a long nail. I have a couple of cord handcuffs that work great to hold everything together but I haven't seen them in many years at any local store. While the reels seem like a good idea, they just aren't too great for my uses. Those H shaped ones would be my least favorite way to wrap up a cord, a real PIA to reel out, much worse than just arm wrapping the cords.
Same here. I sure don't like the starting end of the cord slapping my wrist on every revolution. But cheap has its own price, so I own 4 of them.
That velcro strap seems to work at controlling the "slap;" but I have not tried it yet in "real world" conditions outside.
I see potential problems with that chintzy knob, but for the price and a spare washer I am not complaining.
/ Extension cord reels? #26
I also use the loop through loop one for the "community" cords. No one will touch them because they look like a tangled up mess. But the never tangle
Chevy- I do not think I an coordinated enough to do the loop through loop holder.
Some people put black ink cartridges/refills in those red pen cases too. ;)
It sucks when those expensive cords get "appropriated" by someone else.
I may test the anti-slap strap this PM in real world conditions.
/ Extension cord reels? #30
I havent seen it mentioned about the problem of continuous electrical load on a cord reel.
Even with a well below wire capacity load a coiled cord will slowly develop heat in the bunched wire that is sufficient to melt the insulation. Big, short term loads are no problem for coiled. But if its a small heater or anything applying continuous load more than a couple amps pull the cord all the way out so air can keep it cool.​
SPYDERLK- I never thought about that, but that makes sense. This cord's primary use is for use outdoors just about fully extended; usually to the tractor's engine block and HST filter preheaters. Thanks for sharing.
/ Extension cord reels? #32
:) Sure thing!
I learned that one young and have realized that many dont get the opportunity until too late.​
A contractor at work did a temporary setup running 20Amps through about 100ft of coiled 6ga copper. Fire and toxic insulation fumes began after ~ 30 min. The building was evacuated for awhile to air out. :confused3:
Now you have me thinking about the magnetic field within the reel? :cool: Or that may be a DC phenomena?
/ Extension cord reels? #34
Dont worry on that one. The wires are paired, carrying current to and from. A near total cancellation of magnetic effects -- AC or DC.
Pretty soon there will probably warning labels on extension cord reels about the possible health risks from electrical fields :rolleyes:
/ Extension cord reels? #37
If you put two, side by side, do you have a transformer.
/ Extension cord reels? #38
Not if the current is in the opposite direction in each wire ... just like it is in an extension cord. Coiled or not magnetics are cancelled
/ Extension cord reels? #39
My question was a Joke. “Tongue in cheek”.
There goes the self-administered ECT by placing my head between two reels idea.... back to the jumper cables.
