Loader New member looking for advice on first tractor - digging with FEL
   / New member looking for advice on first tractor - digging with FEL #1
karltinsly
Member
Austin, Texas
Mahindra 2538 HST
I am in the market for my first tractor. It will be used on a 13 acre llama farm that we are setting up. The property is just scrub brush, weeds, and a few trees at the moment. The tractor will be used to clear land, drill holes for fence posts, drive t-posts, and whatever else needs to happen to get the place working smoothly. Also, we unfortunately have to bury the occasional animal, which can take a pretty good-sized hole.
I'm pretty much sold on a Mahindra already. I like the no-DPF engine and beefy construction. Price is nice, too. Local dealers offer packages including tractor, box blade, mower, auger, and transport trailer. I've seen some that have a backhoe as well.
Any opinions are welcome, but I do have a specific question. I'm leaning towards either a 1538 or 2538. Can I use the FEL on those to dig a hole? A friend told me that he thought you'd need at least a 50hp machine to dig with the FEL. As I mentioned, the hole I'm talking about might need to be 3x6 feet by 6 feet deep. It doesn't have to have vertical sides all around like a grave. I know that this is the kind of job a backhoe would excel at, but could the FEL do it?
Thanks for any tips.
   / New member looking for advice on first tractor - digging with FEL #2
No tractor digs well. They are FEL not FED's. Burying a dog is about it for an FEL.
   / New member looking for advice on first tractor - digging with FEL #3
The FEL isn’t the best to dig with- I have the 1538. The post hole digger will need some research as some models don’t go in reverse and can be a real PITA.
   / New member looking for advice on first tractor - digging with FEL #5
No DPF, but instead a DOC. Make sure you educate yourself on that -- no free lunch. I think DOC is simpler than DPF/regens, but they are both systems with sensors and computer control, and complexity. I think Mahindra marketing has done a good job making customers think they met Tier 4 Final magically, but it's just a different type of emissions system.
Unless your soil is very soft, digging is not something a FEL will be good at.
   / New member looking for advice on first tractor - digging with FEL #6
Depending on your soil conditions you may find the FEL adequate to dig a decent sized hole if you use a tiller on the ground first to break up the sod and hard top layer. I did that to plant four trees with rather large rootballs last spring. Root balls ranged from 2.5' to 3.5' diameter. I used my 60" tiller to till about a 4' swath out of the lawn and then used the FEL on my JD 2520 (60" width) to scoop out a V-shaped 'hole' that was deep enough to hold the root ball. Well, actually deeper because I wanted loosened soil below it. I have beautiful black dirt here though, so it wasn't a huge challenge. If you had clay or rocky soil the FEL may be much less useful.
Rob
   / New member looking for advice on first tractor - digging with FEL #7
G'day Mate and welcome to TBN from Downunder.
It sounds like you're more in the market for a skidsteer or a TLB (tractor/Loader/Backhoe).
Honestly, a FEL is designed to lift & carry... scooping/dumping loose soil/material counts as a 'lift' function.
   / New member looking for advice on first tractor - digging with FEL #8
hello karltinsly, you will probably find it is more cost effective to hire a contractor to bury a dead llama, and set the tractor up for the more common farm type jobs that you want to do.
   / New member looking for advice on first tractor - digging with FEL #9
Lots depend on the soil you have.
Thanks for all the input! The farm is just south of Seguin, Texas. The ground ranges from fairly soft to fairly hard, depending on how much rain we've gotten. I think I'll look into getting a backhoe attachment when I get my tractor.
Year: 2013 Make: Ford Model: Escape Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2013 Make...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
Year: 2011 Make: Nissan Model: Sentra Vehicle Type: Passenger Car Mileage: 161,039 Plate: Body Ty... (A55853)
Year: 2011 Make...
2020 CHEVROLET SILVERADO 3500 HD FLATBED TRUCK (A57192)
2020 CHEVROLET...
2024 John Deere 8R 410 MFWD Tractor (A53485)
2024 John Deere 8R...
No runner (A56859)
No runner (A56859)
