"The Beverly Hills property, with a white-brick Regency mansion, outhouses and manicured gardens offering uninterrupted views of the city". I presume they meant outBUILDINGS.
I mounted the magnetic strip to the back of my tractor and use it to temporarily store hitch pins, etc when changing or adjusting implements. It sure beats dropping the pins on the ground, setting them on top of a tire, a fender, inside the cup holder, or just generally misplacing them.
THAT is a GREAT IDEA !!!!
Ditto!!! I need to mount one on my Qhitch!THAT is a GREAT IDEA !!!!I mounted the magnetic strip to the back of my tractor and use it to temporarily store hitch pins, etc when changing or adjusting implements. It sure beats dropping the pins on the ground, setting them on top of a tire, a fender, inside the cup holder, or just generally misplacing them.
YEP!! I have done the same thing. I've been trying to find a broom handle or something similar that I can easily attach one to. Haven't found the right combination yet.I tie the free magnetic tool holders on heavy twine and stick them on the wall around my shops, I've probably one for each shop. Then when I invariably drop a metal part, like a washer, bolt etc. If I can't find it immediately I use the bar to drag and find it. Saves a LOT of bending over.
Going to add that mod to my BX. Good thinking! :thumbsup:I mounted the magnetic strip to the back of my tractor and use it to temporarily store hitch pins, etc when changing or adjusting implements. It sure beats dropping the pins on the ground, setting them on top of a tire, a fender, inside the cup holder, or just generally misplacing them.
I tried to use those to step drill out to 1/2" holes in 3/16" plate, I got 1 and then half of a second hole drilled out of 12 before the 1/2" but melted.When I'm out in the field working on injection pumps, I use the HF magnetic TRAY for things like cotter pins & washers.
That thing is STRONG.. Usually takes 2 hands to break the "seal" once its attached to a flat surface.
I "tried" the titanium drill bits yesterday.. TOTAL JUNK..
Tagged as HI SPEED METEL drill bits.. what a joke.. Had 2 snap off drilling SOFT metal..
Buyer BEWARE..
So far, I have only used it to rough cut bar stock prior to machining. I found it very easy to use and cut quicker than I expected. I did not pay much attention to the quality of the cut. If it was ugly, I would have noticed. This was the Bauer brand one (#63444) that I got for $99. Well worth that cost.
Ken
OT slightly
While we are writing about magnetics -
I've bought a bunch of Neodymium ring magnets of small sizes. I tie them to monofilament or temp glue them on like a piece of 12 gauge bare copper wire to "fish" metal parts out of places they shouldn't be. I've got several of those telescopic magnetic pickup tools but they don't work around corners. I can bend the copper wire to "fish" down a curved pipe.
At times I'm a "fumble fingers" and tend to drop small screw and washers.
One thing brought up recently but we should mention again are the jack stands. Never trust them. I use the six ton ones and if I am going underneath always add an extra one for good measure. Remember what we're dealing with here. For areas where the six tons are too tall I use the aluminum three tons and always a backup if underneath. Just an FYI.
