Wet set concrete anchor brackets pole barn
   / Wet set concrete anchor brackets pole barn #11
I considered the permacolumns on my new 40x60x40 pole building but decided against the mostly due to the additional cost relative to treated posts-our ground conditions just didn’t justify the increased cost.
Additionally they really aren’t quite as capable as a column set in cement when you consider that the lateral loading s transferred through bolt bearing in timber versus transferring in shear in the timber-significant difference in capability-additionally the joint itself is more flexible.
   / Wet set concrete anchor brackets pole barn #12
I considered the permacolumns on my new 40x60x14 pole building but decided against the mostly due to the additional cost relative to treated posts-our ground conditions just didn’t justify the increased cost.
Correction s/b 14 for last dimension
   / Wet set concrete anchor brackets pole barn #13
I ended up building red iron but, when considering a pole barn I was going to use polymer coated posts from these guys - Polymer Coated Wood | Industrial Wood Products | American Pole & Timber. They weren't very expensive and would produce any size post you wanted with as much or as little coating as you wanted. Completely eliminated ground contact and also gave you the shear strength of having the post buried.
Thanks for the pics ! Very nice looking job. Are those 'wall side light panels ? I have then included in my plans, both sides.
Yes, they come in 8' lengths. (I think, can't remember) We cut the size we wanted.
On a cloudy day with all the doors shut you could easily work inside without any additional light.
These pictures it was a sunny day but you can see how much light they let in.
View attachment 539238View attachment 539239View attachment 539240
Thats alot of firewood !! Did you buy your own materials or buy from a pole barn dealer ? That looks like a double truss system ? I have a quote of $32,000 for a 30x50x16 with no floor.
   / Wet set concrete anchor brackets pole barn #16
Simpson doesn't make this type that I know of. Only a couple manufacturers make the wet set that has rebar attached and upper flange connecting with bolts. These Forever brackets are made with 1/4" steel. I would put diagonal bracing in each corner.
Simpson has a similar line:
Post Bases | Simpson Strong-Tie
Their new Movement Post base is rated for shear load:
MPBZ | Standoff Post Bases | Cast-in-Place Post Bases | Post Bases | Caps and Bases | Wood Construction Connectors | Connectors | Simpson Strong-Tie
Yes...it would add about $2500 to my cost.
Thanks will do more research on this product. Hopefully you can just buy the coating and put it on yourself .
   / Wet set concrete anchor brackets pole barn #19
There is always an industry out there making a solution to a problem that doesn't exist. Treated posts in the ground will never rot on you if there isn't any standing water around the posts after it rains. And if you build a building that has standing water around it's walls when it rains, you're building wont last no matter what you use.
Those little brackets remove the sheer strength of a post in the ground, so if you use them, then you need to brace your walls to make up for that loss of strength.
Where you planning on pouring a concrete pad for the post bases? Or where you going to pour an entire footing all the way around your building? Or are you going to pour a concrete foundation with a floor for the entire building? If you are pouring concrete, then stick framing and would be a better option then using the metal bases. Are you planning on insulating it or finishing off the interior walls? If so, stick framing becomes a better way to build then pole building because you will still need to frame up the wall anyway.
Be careful over thinking something that is already well thought out and proven 100 years ago.
   / Wet set concrete anchor brackets pole barn #20
I usually get firewood every year but don't burn it all, so it just keeps piling up.
I bought all the material on my own, the plans were in my head. Kind of made it up as I went along.
In the "Rural Living" thread I detailed the building of my barn. The title is "Raising a Barn".
Mine is 72X57X12 the awning is 12' of the 57'. Total cost was about 30 grand. I did all the work except the concrete and big doors. There were a couple small mistakes along the way, but only a trained eye would catch them. My family and friends sure didn't see any of them.:D
2013 Nissan Juke SUV (A55758)
2013 Nissan Juke...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A53421)
2015 Vermeer SC362...
2019 CATERPILLAR 289D3 SKID STEER (A52705)
2019 CATERPILLAR...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
black Max power washer (A53421)
black Max power...
TAKEUCHI TB250-2 EXCAVATOR (A52705)
TAKEUCHI TB250-2...
