What is this warning light?
/ What is this warning light? #1
Charlie V
East Texas
Mahindra 6500 4x4
I have a 2003 Mahindra 6500 4x4 with 1031 hours. It runs like a top, with the exception of a weak starter. I am new to tractors.
However, a warning indicator lit on the dash today. I have ordered operators, service, and parts manuals, but as of yet I have nothing and Google is not helping.
This is the warning light. I know red is bad. But I cannot make out the symbol or guess its meaning. Anyone?
Thanks,
Charlie V
/ What is this warning light? #2
I’ll take a SWAG and give this a bump-
Based on what’s around it is seems like an overrev/upshift light. The other lights around it are related to the transmission and lighting.
Again total SWAG and a bump for ya!
/ What is this warning light? #3
IF this was October I'd say your machine was wishing you "Happy Halloween".. looks like a pumpkin.
Sorry couldn't resist.. no help here.
/ What is this warning light? #4
Maybe it's an airflow indicator arrow going down with a NOT on top of it... indicating dirty air filter... Heh, a guy can guess, can't he... ?? :)
/ What is this warning light? #5
Couple of things...My 6000 (an '02) has a red light that comes one right after I start it, but still idling...its right above the voltmeter...once I move the throttle up past 1000 rpm, the voltmeter moves up to 14+ volts and the red light goes out...and doesn't come back on...now as far as the weak starter...Mine also has the same starter...I wasn't sure if it was the battery or not...changed the battery, no joy...finally ordered an after market starter about a year ago and it comes to life, even in 20 degree weather like new...I think I paid about $190 for the new starter...worth it big time. good luck with the 6500. BobG in VA
I ordered a new starter last night after posting, along with some replacement lights, rops brackets for LEDs, etc.
At first, I thought it was a battery, too. I swapped another battery and got the same result (weak or no start). I tried jumper cables from a running backhoe to the battery and got the same result. So, as a last check, I added 12 volts to the starter (24 total) and the start was immediate and strong. So, the starter is failing. I considered taking it for a rebuild but having a spare is good, too. A new one was about 160 and should be here in a few days.
I have that same LED right above my voltmeter. When I first bought the tractor I thought it was for glow plugs. I guess that is a low battery or voltage light?
/ What is this warning light? #8
Your warning light looks like the same one as #8 for MF http://www.tractorbynet.com/forums/hydraulics/357655-mf-5455-warning-light.html
It might be a Low Coolant warning. (edit) - After seeing the image closer it does look more like a filter image like CobyRupert suggested. I did find a couple images from MF and JD, and a JD manual page. It is an exact match to your light and says it is indeed the airflow indicator warning. It says the air filter needs cleaned or replaced.
For your starter, have you checked the volts getting to the starter from the battery? Could be bad cables or poor connections.
It sure looks like a lot of other air filter warning lights.
air filter warning light - Google Search
It sure does; and thanks for the links.
Unfortunately, that picture I took isn't out of focus; the tractor sat out before I bought it. Apparently, Mahindra depicts the air molecules as dots, instead of the filter media.
I am going to get new inner and outer filters and see what happens.
Thanks to all, for the suggestions.
Best,
Charlie V
It does. Is #8 the air filter/flow?
I did not check the cable (it goes straight from the positive terminal on the battery to the starter, then smaller wires go to lights, etc.) or the voltage--I was in the field--but I did try to start with cables directly to the starter and got the same result. If it is the cable I am going to be real irritated with myself for getting a new starter! I will know in a few days and post the result.
I'm already irritated with myself for removing the tractor battery and replacing it with the (bigger, stronger) one from my old mercedes diesel that was sitting in my pickup, awaiting installation. Now the car won't start. :hissyfit: I will swap it back when I put the new starter in. Mahindra batteries are in a really inconvenient location, it seems.
/ What is this warning light? #11
- The other JD manual I found had a better image of the indicator and also showed the description which instructed to clean/replace the air filter.
- Jumper cables directly on the starter should eliminate battery cable issues as the problem.
I think so, too. It only started when I doubled the voltage by attaching another battery to the starter with the tractor battery already connected. Both batteries were good (I checked later).
Oddly, it started again and again with only one battery, that day. It "fixed itself".
Or, it didn't . The next day I got the same weak/no start. I repeated all of the steps I tried already, and really stared at the starter in a hateful way. I think that's it.
Unfortunately I filled it with diesel and the fuel line/banjo fitting has to come off to get the starter out. I now have special clothes and a special spot on the ground for starter fixes.
Thanks for your reply.
/ What is this warning light? #13
Sorry I'm late to the party, but my manual confirms what you now already know - Mahindra calls it a "Air Filter Clog Indicator", they advise it comes on when the filter needs cleaned so you might try that before getting new ones.
Never too late! The filters are on the way but I will try blowing out the existing ones and may keep the new ones in boxes. I am just glad that it isn't a more serious problem. Judging from the simplicity of the engine, I really doubted that the indecipherable icon concerned a subtle issue, and the tractor seems to run fine. When my manuals arrive I will change all fluids and filters and become more familiar with it. Thanks for your (definitive) response.
Just a quick follow-up up.
I pulled the filters and shook them off, then blew compressed air from the inside of the outer filter, reinstalled them, and no more light! A rare success!
Thanks to all for your comments.
/ What is this warning light? #17
Good is this life....!!!!!!!!!!!!!!!! :) :) :)
/ What is this warning light? #18
Like Charlie V said. Never too late. I just replaced the power steering cylinder seals and this light was on when I fired everything up. I guess I must have rested my knee on the filter when I was pouring in the fluid? Gonna shake out the filter tomorrow and be a happy camper! Thanks
/ What is this warning light? #19
This is the airflow light. There is a sensor with 2 wires on it just after the air filter. If water sits in the little box where the wires plug in it will short across them and the light comes on.
2019 FORD F-350 SUPER DUTY (A65643)
2019 FORD F-350...
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
MAXILATOR SQUARE BALE ACCUMULATOR GRAPPLE (A64277)
MAXILATOR SQUARE...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2017 BOBCAT E50 EXCAVATOR (A63276)
2017 BOBCAT E50...
