How do you fill your 10 series with a field cab?
   / How do you fill your 10 series with a field cab?
I dont but that's a really good idea, already thinking of other uses for the pallet forks
   / How do you fill your 10 series with a field cab? #22
They’re pretty handy. You can get forks that clamp on your bucket but, if it were me I’d get a real SSQA pallet forks matched to you FEL capacity.
Mine are 48” x 4000 lb. and I can use them on both of my tractors.
   / How do you fill your 10 series with a field cab? #23
I have a 2018 ck3510 with the field cab and I to struggled with a way to fuel the tractor without making a mess. I discovered the Pocketpump located here.... Pocket Pump Ltd. - Heavy Duty All Purpose Pump
I bought the pp075 model.....runs off 2D cells....for $39 cdn works awesome...no more spillage and no fuels left in cans.
   / How do you fill your 10 series with a field cab? #24
Just a siphon hose. I stole many a gallons of my parents car gas for my Honda CT70 back when you could siphon tanks.
Just don't drink any.
   / How do you fill your 10 series with a field cab? #25
Ditto, I have a couple of these. They work great. Don't last very long but cheap. $15-$20. Even the wifey can use it to put gas in the lawn mower.
   / How do you fill your 10 series with a field cab? #26
Here’s similar at Home Depot and eBay has several for under $10 with free shipping.
I use one to fill my kerosene shop heater. Very handy.
DuraHeat Battery-Powered Siphon Pump-DH-2 - The Home Depot
They also have manual versions with a squeeze bulb at top.
DuraHeat Plastic Siphon Pump-DH-1 - The Home Depot
   / How do you fill your 10 series with a field cab? #27
You got that right.
   / How do you fill your 10 series with a field cab? #28
55 gal barrel on the roll around wheel thingy and a hand crank is easy and pretty cheap. Just don't trust the tractor fuel gauge...'cuss it's really slow catching up with the tank volume...mine says 3/4 tank when it starts running out on the concrete...learned that the second time.
By the way, I haul 2 barrels to the off road diesel store in a trailer and welded about 4' of 1/4" chain on each side of top ring of the barrel (before filling them the first time) and this works great to pick up barrels, full or empty with the bucket or backhoe.
BTW...cabs are great and so is the heat and A/C...can't believe I suffered for so long out in the weather...yeah...I'm getting old and soft.
2012 CATERPILLAR 305DCR EXCAVATOR (A52707)
2012 CATERPILLAR...
2021 Deere 333G (A53317)
2021 Deere 333G...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
Case 1020 25ft Draper Head (A55315)
Case 1020 25ft...
Hose Reel (A55787)
Hose Reel (A55787)
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
