Ck30, is this where I add hydraulic fluid?
   / Ck30, is this where I add hydraulic fluid? #1
atcNick
Longview, Texas
Still shopping
After the leak I had I figure I need to top off the hydraulic fluid levels. Is this the dipstick for it and where I add it?
   / Ck30, is this where I add hydraulic fluid? #2
Yes and yes. Engine off.
   / Ck30, is this where I add hydraulic fluid? #4
I use the tractor supply traveler premium universal tractor trans hydraulic fluid., and I've heard of many others doing the same. This assumes you have an hst. If gear, I don't know.
My ck30 is not hst
   / Ck30, is this where I add hydraulic fluid? #6
Look in the manual. Or wait for someone else to respond. It may be the same, but I'm not sure.
It's important to know how to check all fluid levels, and keep some extra fluid around.
I don’t have a manual. Bought it used and it didn’t come with one. After doing some searches it seems to be the same. I don’t suppose if it’s topped off with a different brand or type it would cause any problems?
   / Ck30, is this where I add hydraulic fluid? #8
How many hours? How much fluid was lost? When I damaged my hydraulic oil filter housing, I lost a ton of fluid. So, I just changed it all. You might consider doing a fluid change, and changing the filters. Especially if you don't know the hours on your fluid /filters.
295 on the hours. I had all fluids replaced when I bought it maybe 40 hours ago. I suspect it’s no more than a gallon or so down. I hit a hydraulic hard line and leaked some fluid for a couple minutes before I noticed it
   / Ck30, is this where I add hydraulic fluid? #10
Call the place that changed the fluid and find out what they used.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
S/N: 1240824 (A55853)
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
UNUSED SDLANCH 72" QUICK ATTACH BUCKET (A57193)
UNUSED SDLANCH 72"...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
Air Chipping Hammers (A55851)
Air Chipping...
