MT 1 25 Slppy FEL
   / MT 1 25 Slppy FEL #1
H8Monday
Payson, Utah
LS MT1 25
MT 1 25 Sloppy FEL
New MT125 owner here. Picked up my LS x for it? Itjust before Christmas this year, and have 20.6 hours on it now.
Even when brand new, I couldn't help but notice how much 'slop' there is in the FEL bucket. Have any of you noticed this? or have a fix for it?
It seems that the fit of the pins in the linkage is pretty loose. Is it just mine? or is it all through the model line?
-Todd-
   / MT 1 25 Slppy FEL #2
I have an LS MT125 and the bucket is tight and secure. If you could post some pictures of exactly where yours is loose I'll compare that to mine but I would not complain about my bucket.
Hope this helps .
   / MT 1 25 Slppy FEL #3
I haven't noticed any slop in mine, nice and tight. Have 97 hrs on it. If you have the bucket curled up, then lower the loader assembly to the ground, it will curl the bucket up just a little more, then drop it a little when you raise the arms. Mine does that.
   / MT 1 25 Slppy FEL #4
Re: MT 1 25 Sloppy FEL
-Todd-
Mine are very much in line with most every subcompact tractor I've used. The only way they would be any tighter is if they were brass lined bushings like professional equipment has. I keep a good HiTac grease in mine which makes it feel better to me. I grease it a lot also. Basically, every time I use it. Tony
   / MT 1 25 Slppy FEL #5
A good greasing schedule is the key and will "tighten" things up too. Plus it flushes out any dirt that may work it's way into those joints. Keep the grease gun handy.
   / MT 1 25 Slppy FEL #6
I agree!
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2016 WESTERN STAR 4900 SB DAY CAB (A58214)
2016 WESTERN STAR...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
2016 John Deere 5055E 55HP Utility Tractor (A55973)
2016 John Deere...
2019 Deere 550K (A53317)
2019 Deere 550K...
JOHN DEERE 300 GALLON NITROGEN APPLICATOR (A52708)
JOHN DEERE 300...
