Which of these fill first?
   / Which of these fill first? #1
2ndhalf
Central Ohio
Gravely ZT HD 60, MF GC2400
This is floating around facebook.
   / Which of these fill first? #2
3. 4 and 5 is blocked and the left pipe is lower in 1. If you ever underestimate how stupid most people are just go read the Facebook comments on these things.
   / Which of these fill first? #3
3 for reasons above
Ha ha I did and agree with you!
   / Which of these fill first? #5
Missing a blocked pipe is understandable, but a lot of people don’t understand that water runs down hill.
   / Which of these fill first? #6
the ? is how full is considered filled. otherwise 1 gets filled first. :confused3:
   / Which of these fill first? #7
I think for the puzzle to have any meaning you’d have to assume the flow rate is low and they meant filled to the top.
   / Which of these fill first? #8
Since the "artist" is playing tricky with lines on ends of pipes representing a plug, then no cups will ever fill, as the the faucet is also plugged, and has no supply pipe.
Why not have a real test of water flow knowledge without any tricks? If all was functional, which would fill first? I bet there would be many wrong answers anyway.
Bruce
   / Which of these fill first? #9
Number 3... and it will continue to overflow, not filling any other. Mind you, 'they' don't say what the flow rate out of the faucet is.
This is true even in "Downunder" conditions.
With the water/fluid swirling in the "opposite" direction". :)
   / Which of these fill first? #10
This is an excellent test, and in this day and age of deceptive advertising,, this should be taught in our school systems,
I did well on IQ tests when I was in the public school system, as one time I had a teacher that taught the simple aspects of deception,
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
EZ-GO Electric Cart (A55853)
EZ-GO Electric...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
