New problem tighten bolts
/ New problem tighten bolts
I always knew JD liked to be proprietary, but I guess I never knew how much.
/ New problem tighten bolts #22
What does JDM stand for? and, ASTM?
I always thought SAE was the standard.
JDM = John Deere Material
SAE = Society of Automotive Engineere
ASTM = American Society for Testing and Materials
/ New problem tighten bolts #23
The clutch pack to flywheel bolts should be 3/8" bolts. Grade 5 should be 35 ft/lbs and grade 8 can be up to 50 ft/lbs/. For this application I have always torqued them to 35. Never had one come loose in 40 years. Are you sure the spec you were looking at wasn't for the flywheel bolts that hold it to the crankshaft? They should be 120 ft/lbs if grade 8. 85 ft lbs if grade 5. I would not use 120 inch lbs. That is not enough... equivalent to 10 ft/lbs.
By the way, I think the stripping sensation you were getting was the bolts stretching. Compare to a new bolt and you will see the difference in length.
/ New problem tighten bolts #24
Many large OEMs create their own standards... usually very similar to National or Industry standard but they may have a specific requirement or two that they want to be assured of, and they can control their purchasing and receiving better in some cases. Does drive cost though because often it means additional qualification/certification testing to verify.
We have it together. Used new grade 8 bolts. We torqued it to 40 ft/lbs and used loctite. Just need to finish the little stuff which we will finish tomorrow.
Thanks for all the information and adding to my education.
KUBOTA L3940 TRACTOR (A64277)
KUBOTA L3940...
2003 International 4300 Bucket Truck (A62613)
2003 International...
2012 MACK GRANITE-GU713 (INOPERABLE) (A65643)
2012 MACK...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2010 INTERNATIONAL WORKSTAR 7400 BUCKET TRUCK (A65643)
2010 INTERNATIONAL...
2020 International HX620 Quint Dump (A62613)
2020 International...
