Snow B26 owners and snow handling
   / B26 owners and snow handling #41
Very nice powerstroke..I would love to see video of that tree shear in action....I have a root grapple for my b26 works great..interesting though about the shear....amazing what kind of attachments can go on the b26... these tractors aren't just meant for renting ( like they were built for ) ....
Also thanks brkgi I am loving this cab..if anyone has the means to buy one for their b26 I highly recommend it...just a little note..it comes with side steps..which extend past the tires..take them off or if you forget about them,they will get ripped off by something you over look.!!
I haven't figured out how to do video yet but did get a few action shots today. I had the hoe on for counter balance I should make a 1000 wieght rack as several times it was tight moving around the good trees with hoe. IMG_20180120_132025714.jpgIMG_20180120_110647855.jpgIMG_20180120_115721436.jpgIMG_20180120_115717548.jpg
   / B26 owners and snow handling #42
Love that tractor and tree shear Powerstroke. Where did you get the tree shear?
   / B26 owners and snow handling #44
Skyhook, I see you've got lots of replies, some from those who actually own a B26. A few additional thoughts as a B26 owner, I have a 1/2 mile gravel drive in the mountains of NC that runs about 8 -10 percent grade the whole way up. We usually don't get that much snow but when we do I use a rear mount grading blade and the FEL. I back drag (or push) with the blade to minimize gravel loss and usually have no issues. I make the initial pass going downhill with maybe a second cleanup pass going back up and that usually works well unless there's ice. Level ground I have no issues but chains for the rear is the one add I want to make for icy times on the main grade, otherwise this approach works well for me. Since I'm seriously not into buying and changing rear wheels and I always seem to have one or both off the ground for hoe work on my property, I wouldn't consider filling the rear tires (as was mentioned, Kubota recommends against this for this model). I could see weight making a difference with a big heavy wet snow on pavement but if that's the norm, a bigger tractor is probably in order - not filled tires. Another consideration, as it is I have to gear down to medium range to get up the steeper parts of the driveway (w/B/H on), I wouldn't want to have to drag around another 500 -1000 lbs. every time I head back uphill. The tractor is bullet proof and very capable but at only 26HP with a hydrostatic trans. travel speed takes a hit on steep slopes.
   / B26 owners and snow handling #46
I'm probably jumping here far to late but I've owned a B26 for coming on nine years and I also have a cottage in snow country where we get snow by the yard (Ok meters 'cause I live in Canada)
I have a Pronovost Puma 46" blower which has never given me any grief. That's the largest blower I'd go with, for weight and power. If I had to complain about one thing on the B26 it would be horse power. I'd love to have maybe another 5 HP but, for all that, if you know and stay within your limits it's a great machine. I haven't loaded my rear tires but I do have aggressive V bar chains. I have a fairly steep gravel hill to clear and I've never had a problem going up or down no matter the weather. The chains will tear up asphalt or concrete so if you have a paved driveway, V bars aren't the way to go.
I've read some that it's not recommended to chain up the front tires when using 4WD. Something about breaking gears but I don't know that for a fact. I've cleared snow for nine winters and never felt the need to chain up my front tires and maybe have an expensive problem later.
In another post I did write about a problem I had last winter with my range selector dropping into H from M. I was at the bottom of the hill and when I tried driving back up the tractor bogged down and almost died. I couldn't figure what was going on until I realized the selector was in high. I just thought I'd bumped it until it happened again. The selector had disengaged from the tranny and I had to make up a small bracket to keep both into contact. It just seemed like a poor design that something like that could even happen. It wasn't damaged and the tractor only had about 550 hours on it. Go figure.
2026 Kearney 7' x 20' Trailer (A53317)
2026 Kearney 7' x...
Ratchet Straps (A55852)
Ratchet Straps...
John Deere 187B (A53317)
John Deere 187B...
2016 Dodge Ram 5500 Lube Truck (A55852)
2016 Dodge Ram...
UNUSED RAYTREE RABC44-44" HYD (A57193)
UNUSED RAYTREE...
2013 Ford F-150 Crew Cab 4x4 Pick-up Truck (A55852)
2013 Ford F-150...
