kioti lk3054 potential purchase
/ kioti lk3054 potential purchase #1
Diesellucy
Burton,Oh
ford 640, farmall cub. gravley l, gravely li
I am considering a Kioti LK3054 tractor loader and backhoe with 373 hours. its about 12 years old. the local dealer has all the records on this machine. were there any issues with these tractors
/ kioti lk3054 potential purchase #2
Mine's about that vintage with ~950-ish hours and has been trouble free. No backhoe, just tractor/loader.
/ kioti lk3054 potential purchase #3
Thatç—´ pretty low hours. Can you tell us more about the backhoe? Brand, dig depth, bucket size? Chassis mount vs 3 point hitch mount? Driven off the PTO or rear remotes?
I ask because the backhoe is s big value add on the tractor, but a 7.5gpm pump, youæ±*e going to have limited capability with it.
/ kioti lk3054 potential purchase #4
I own an '04 3054xs tlb, with a little over 600 hrs, purchased new. It has been reasonably trouble free, but is very cold blooded (read hard starting in cold weather). The only warranty work was a clutch issue, actually a pressure plate issue. The tractor is equipped with a Borg and Beck type plate utilizing a three finger design and one of the "fingers" failed rendering the clutch inoperative. It is a very basic tractor with no electronics and a manual cable fuel shutoff. Mine is equipped with the standard Kioti 7.5 ft hoe and has more than enough power; will drag the machine all over the lot if you want
/ kioti lk3054 potential purchase #5
That sounds like a pretty good endorsement to me.
its the factory backhoe, sub frame mount pto powered pump
/ kioti lk3054 potential purchase #7
My hoe is sub-frame mounted, quick detach (frame stays with tractor), and operated by tractor hydraulics
/ kioti lk3054 potential purchase #8
That PTO powered pump may actually have more flow than the onboard pump. The PTO has about 24hp and could drive a pump that has more than the 7gpm that you壇 get from rear remotes. This would actually be a more expensive configuration.
/ kioti lk3054 potential purchase #10
The sub-frame is attached to the differential housing with support arms (right and left side) running forward and secured to the loader frame. Very substantial mounting system and doesn't impact ground clearance
/ kioti lk3054 potential purchase #11
Mine has two U brackets that the subframe slides into and is locked in with two Lynch pins. It痴 nice and solid but I lose about 4 of ground clearance
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2017 PETERBILT 579 (A65643)
2017 PETERBILT 579...
Mini Universal Tree Spade (A65640)
Mini Universal...
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
