buckeyefarmer
Epic Contributor
Even the yearly pass, which i buy occasionally, are nice laminated cards. Mine still good till june, bought it at petrified forest NP on way to grand canyon last yr.Mine is plastic like a credit card.
Need to fill bird feeder again today. I started out with 200 lbs last October. Now down to last 20lbs. Been refilling the one 3 gallon feeder every 3 days since Christmas. Mostly feed Chickadees and sparrows. Blue Jays, Woodpeckers, Cardinals and Doves also feed. Squirrels cannot get to feeder. But do feed on the ground. 2 or 3 deer stop by at night. They also feed off the ground. Anyone else feeding a large amount of bird seed?
Need add to my list of thing to do today. Buy more bird seed. Winter is not 1/2 over yet.
Picture was taken in October.
Parboil something to go in the smoker? NO WAY! I think there are laws to keep people from doing that.
Sounds like they foil over their meat to get it cooked quicker and only get smoke on it for a short time for a little smoke flavor. Sounds like tourist food. :laughing:
I have not posted a picture here in years.
The tractor.
The ribs.
The tractor.
The ribs.
OK, I think the terminology you are looking for is a "system malfunction" - According to the article under the Facebook pic it said it was being used at the time of the fire to make FF. Since there is an electrical burner element at the top of the machine we could speculate an unspecified electrical short or overheating. Careful examination of the burner and wires to see if there was any arching might reveal the exact cause of the fire. If it has a thermostat it could have malfunctioned or been defective causing the element to overheat and ignite the plastic outer cover. But I still would like to rule out that back left burner by checking the location of the notch on the metal rod on the burned stove control knobs. Also kind of leaning to the overheating because a breaker should have tripped if there was a short, got to check the breaker box also.
Good morning all. Could not sleep so I finely just got up and started catching up on Good morning. I must be reading slower, it takes longer than it used to. 32 now, supposed to go down to 16 and then up to 49. Don't think we will make 16 tonight.
Randy, You are stringing this tractor buying thing out a long time. Just go ahead and buy it! Hope it works out well for you.
Have a good day. Ed
