which portable generators do people have
   / which portable generators do people have #331
I have no issue running my Jet pump on my 3.7 K Yanmar portable if need be. That and some other stuff.
You are brave, I would not pee on 3.7K. That might scorch your jet pump :D
   / which portable generators do people have #332
Useful for?
   / which portable generators do people have #333
It is now a requirement for me... that and being able to pee outside without getting arrested. :D
I figure you should be able to pee off your front porch and shoot your supper off your back porch...
Happens all the time over here...
DM
   / which portable generators do people have #334
DM
All well and good unless you get the two mixed up :irked:
   / which portable generators do people have #335
Going sideways on the thread but... city water is for the pigeons. Never in my life have a tasted city water that tastes good or even close to well water. My data points for city water are Seattle/Bellevue Wa, Berkeley/Oakland/SF/LA Ca. and every hotel around the world. My well water is far better tasting and so so much cheaper! Same with the well water from my previous residence. It is now a requirement for me... that and being able to pee outside without getting arrested. :D
The best water I have every tasted is from my well outside Olympia WA... cold, crisp and fresh... it's the Artesians you know! (At least this is what Olympia Beer claimed)
The water in the mountains in Austria was also wonderful... but that changed when municipal water came to be...
My friends from Austria asked how can Americans drink Swimming Pool Water?
One of the biggest reasons for most to have a generator is to power the well pump... unless you have natural 35 psi spring water like my brother has... it was even famous once in case if anyone has ever heard of Alhambra Spring Water... there really is an Alhambra Spring even thought today it is just marketing...
   / which portable generators do people have #336
I know you get it. Spring/well water in the PNW is second to none. My dad loved the artisan water... admitting here, Olympia Beer was his source. :D
   / which portable generators do people have #337
It's "The Water" after all... still artesian water in downtown Olympia folks line up for...
Getting way off topic... one of my favorite places to dine is the Falls Terrace in Tumwater... just across from the Olympia Brewery complex...
   / which portable generators do people have #338
I agree on the deep well water quality!!
I'd like to mention that the ability of your generator to properly start & run your well pump is largely determined by the depth of the well (head pressure).
Mite be a good idea to actually measure the in rush current of your well starting in order to properly size a generator.
That's very important of you want to minimize the generator size.
My Generac xl4000 which is rather weak had no problem powering my well pump because the water level is at ground level and only 20ft down at the most.
When I bought my Yanmar L70 engine I mated it to a 5kw generator head which gives it a bit more surge capability.
It also pulls over 4kw and holds voltage until the engine gets loaded & dragged down due to load.
90cummins
   / which portable generators do people have #339
I have artesian water for our water source here on my place, it shoots out of the ground, into a big cement box and has two over flows. you can see one of the over flows in this pict.,
It's very cold and fantastic tasting...
SR
   / which portable generators do people have #340
The pioneer family that settled the valley choose this precise location due to having water...
Old news account from a 100 years ago said the family was most generous during the drought... not turning away any of their neighbors in need when the wells dried up during the record drought...
The ironic thing is my brother has deeded water rights to this little spring... through the years the deeded rights are 2,000 gallon daily minimum... he very much wanted to put in vineyards, etc... spent over 30k drilling two dry holes... had the geologist out, did soundings, historical maps, witcher, etc... the second hole stopped just shy of 700 feet....
It is a sore subject in the house... his wife said do you know what we could have done with 30k????????????
Oh... they have the Honda 2000 inverter generator for use around the ranch... plus two separate metered services...
Good site for solar... really ideal but the solar money was spent on the two dry holes!
30008 (A53424)
30008 (A53424)
2022 CASE 850M LGP CRAWLER DOZER (A52706)
2022 CASE 850M LGP...
1998 National RV Tropi-Cal T/A 35FT Class A Motorhome (A55853)
1998 National RV...
KUBOTA M7-132 (A53084)
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
