MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,501
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Just so you know... and sure, its highly unlikely till it happens to you or someone you know...
Be safe.
CDC - NIOSH Update - NIOSH Warns: Improper Hitching to Tractors Can Be Fatal
Typical Cases
On September 3, 1991, a 71-year old male part-time farmer was fatally injured when his 1950-model tractor overturned to the rear while pulling a downed tree. He suffered multiple trauma with a fractured neck and jaw. The tow chain used to pull the tree had been hitched above the drawbar of the tractor. The tractor was not equipped with ROPS.
On December 3, 1991, a 33-year old male farm worker died as a result of multiple head and trunk injuries when the 1958-model tractor he was using to pull a pickup truck filled with wood overturned to the rear. The tow chain had been hitched high on the back of the tractor. The tractor did not have ROPS.
On January 3, 1994, a 42-year old female farmer died from chest injuries when a 1970-model tractor she was using to pull a loaded pickup truck out of snow overturned to the rear. The tow chain had been attached at the top link connection of the tractor's three point hitch. The tractor did not have a ROPS.
On June 22, 1996, a 29-year old male died from multiple crushing injuries when his 1950-model tractor flipped over, pinning him underneath. The operator of the tractor was clearing trees and brush in the yard of his newly built home. The tow chain was found to be attached to a six inch tree stump, and fastened at the top of the three point hitch attachment
On October 29, 1994, a 13-year old male sustained severe fatal head trauma when the 1953-model tractor he was using overturned to the rear while pulling a felled 18 inch diameter tree that was still partially attached at the stump. The tow chain had been hooked directly around the rear axle.
Be safe.
Typical Cases
