3-Point Hitch PTO Generator arrived today
   / PTO Generator arrived today #11
I've never understood why think they shouldn't/couldn't run their tractor 24/7?? YET, they think it's fine to run a small much less reliable and weaker Honda, Generac, B&S or Kohler 24/7...
Lots of pumps have the same diesel engine that's on a tractor, irrigating fields for days on end, used year after year.
I've baled hay at "pto speed", loaded pretty heavy with a baler, from morning to night, day after day. I guess you wouldn't do that with a tractor either??
So, I have no problem leaving my tractor run as long as I need it to run and IF I felt uncomfortable doing so, I'd say I bought the wrong brand of tractor in the first place!
SR
   / PTO Generator arrived today #12
Amen to that! Lots of standby generators are diesel also, and they start up and go wide open! No idle time what’s so ever. Just keep fuel to it and let it run!
   / PTO Generator arrived today #13
I have run my pto generator almost non-stop for long periods of time, several years ago it ran for ten days almost non-stop. I'd shut off the generator once a day to take the tractor to the fuel tank and then back it up reconnect and go again. That was using my Oliver 1550 that had several thousands of hours on it, I even went so far as to mark the oil dipstick with a running full mark. Now I normally use my Branson 8050 on it, this tractor has an economy 540 gear that lets me have pto speed at 1750 engine rpm, I have used my IH 574 on it using the 1000 rpm pto at half throttle, it works for night loads , lighting, oil furnace and water well pump during the day when the load varies so much more it has trouble holding steady enough so I take it back to the 540 shaft and more rpm. Now with less people and loads some nights I shut down for 4 hours or so and then restart for an hour but that's mainly for fuel conservation ($$$$) then any other reason. Of course I am considering a small low rpm diesel gen-set also.
   / PTO Generator arrived today #14
Everyone's circumstances are different. But in a power outage, we run our generator 3 hours in the morning and 4 hours in the evening. Any more than that is just a waste of fuel and added wear & tear.
We have wood heat also.
   / PTO Generator arrived today #15
For my circumstance I chose spending 5k for a 16kw generac and home auto switch. I thought about getting a PTO Generator but chose the Generac for several reasons over the PTO generator.
1) Didnt want to tie up the tractor from other things like snow removal. Generator was 5k installed and is dedicated-has cold weather package and runs on unlimited natural gas.
2) did not want to leave tractor running overnight
3) Takes time to warm up tractor, connect and fuel up.
4) My tractor and implements cost me around 25 grand not including PTO generator and hookup to house if I got one. Generac was 5.5k hooked up including house autoswitch. Generator has 10 year warranty-when it goes I just buy a new one for 1500 to 2500, hookup is already there.
5) Generator is always waiting and it exercises itself bi - weekly.
6) Diesel is more expensive than NG and I dont have to store gallons on site and dont have to worry about gelling or treating. I dont have to fuel up every 12 hours and I can run my Generac for several days without needed downtime.
7) love my MF too much to leave it outside in bad weather or for thieves to come get.
8) If im on vacation and power goes out whos gonna setup my MF and run it? My hot tub would freeze up, my pipes would burst.
Nice backup plan option for me but for now Im good with just the Generac.
   / PTO Generator arrived today #16
Was seriously interested in upgrading my emergency power capability and this thread gave me reason to enquire so, I sent an email to IMD and asked. This is the response I got.
Ron,******
*************** Thank you for your interest in our products.
We generally recommend that you have 2 PTO horsepower for every 1 KW. So you would not be able to fully compensate for the power draw of our 10KW. You could pull about 7 KW out of any PTO generator but you could run into the issue pulling more than your tractor could handle. This could cause a drop in Hz and offset your voltage output. So it is possible to run but there is risk involved.
Best regards,
Shane Huffman
Plant Manager
IMD LLC
Tel.: 864.968.0858 Ext:14
Fax: 864.968.0878
www.imd-us.com
Pretty much confirms what I had previously discovered. Settles the issue. My Ford 1210 only has 13.5 PTO horse power. Not sufficient to safely power a 10k generator. Guess I'll stick with my Onan 4500 and be satisfied with it till the power comes back on.
This I know. This is the last all electric home I will own and although this is not my first experience with a heat pump, it will be my last. Of course, this depends on where I relocate to once my other half retires. Looking like MS or maybe southern TN. I'm hoping for S. TN. My next home will be natural gas or propane.
Rams
   / PTO Generator arrived today #17
Let’s just hope you don’t loose natural gas during the power outage, my point being there not 100% fail safe.
   / PTO Generator arrived today #18
As my ole Pappy used to say, if man built it, it's gonna break or fail at some point. Nothing is 100% failsafe. Actually, I prefer propane.
Rams
   / PTO Generator arrived today #19
A lot of places don't have natural gas available, and up in the northeast to my knowledge there are only a few main lines feeding it with several booster stations, the booster stations are relatively new the pipelines are not, who knows what the future will be for them.
   / PTO Generator arrived today #20
Absolutely everything breaks.. I burn coal so I hate propane! Lol
1270 (A50490)
1270 (A50490)
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A50854)
2019 TRITON...
2018 FREIGHLTINER CASCADIA TANDEMA AXLE SLEEPER (A52141)
2018 FREIGHLTINER...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
