Needing some serious help
/ Needing some serious help #1
1966Chevy
Oklahoma
John Deere 4230
So I was working around in the 4230 and I pulled one of the hydraulic lines to move it around to a better spot(blah blah), I then went to put it back in, it went in and I gave it a little pull to make sure it would stay in. it came back out so I kept trying to get it in better. during the process the assembly went in and locked as if it was connected even though it isn't and now I can not get it to unlock. help? please?
/ Needing some serious help #2
Did you shut the machine off and relieve all the pressure in the lines? 1st
Then grasp the fitting and push it further onto the its mate and pull the collar back. 2nd
The should come apart. If not then I am in the same position as you, stymied.
i had it off and all hydraulics in neutral
should I try starting it to add pressure to try and get it to pop out?
/ Needing some serious help #5
Are these the lines for your loader? If so, try working your valve in all directions several times to allow pressure to bleed off. Also, is the loader on the ground so it is supported? What kind of connectors are you using? Picture would help.
do not currently have pictures, and loader is still completely on the tractor and I only took 1 line off because it was rubbing against my 3 point, unhooked it to re route it so that it wouldn't be rubbing and now can't get it to go in. it's acting like it has a connector in it because the little balls in the tractors connector will not go in, just using factor SCV(I think they are called) connectors
/ Needing some serious help #7
If the loader is supported by the cylinders and not the ground you will have a extremely hard time connecting. Do you know which line you removed? Was it for raising or lowering the boom or the curl cylinder? You will need to get the pressure off the cylinder.
there is absolutely no pressure in the lines, I can push in the ball and fluid come out. im talking about on the back of the tractor, where you connect the line into. that's the bit that is stuck closed. what in pretty much needing to know is, let's say the line is perfectly fine and connected. how do I disconnect a line?
it's not that type of coupler, here's some pics to help possibly 510%2B9dqo7FL._SX300_.jpg71Z7VREV-tL._SL1500_.jpg
/ Needing some serious help #11
I am not sure on how to disconnect. The only John Deere I ever had to hook up to was a 4020 and that was 30 years ago. Seams like we had to push down on that lever and the hose would just pop out. Sorry I can't be more help.
/ Needing some serious help #12
Looks to me like two way couplers in a housing.
Meaning you push your hose in and it locks. You simply pull on the hose to disconnect.....because the coupler is mounted by the collar.
Its called breakaway protection. Incase you drive away from something and forget to unhook the hoses.
I am guessing when you "thought" it was connected.....and you pulled on it and it came back out......I am betting it was indeed connected and working just fine. Simply pulling on it is how to disconnect
Nearly what happened, while I was trying to hook it up, the sleeve went back in. carefully pulled it back out with a flat head and everything is working now. thanks
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
(4) SIDE BOXES (A63569)
(4) SIDE BOXES...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
CHEVY DUALLY TRUCK BED (A63569)
CHEVY DUALLY TRUCK...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
