Loader Control Freezing
/ Loader Control Freezing #1
avc8130
Northern, NJ
Kubota L45
This winter my loader control stick seems to be freezing up when the machine sits. The joystick appears to actuate the valve through a few push/pull cables.
Any suggestions to remedy the situation?
/ Loader Control Freezing #2
My guess is cable has moisture inside rubber covering which is turning into ICE. If I'm correct one needs to eliminate the moisture or park tractor in heated area.
/ Loader Control Freezing #3
I agree. See if you can move it to a heated place or warm it up somehow. It's probably ice.
/ Loader Control Freezing #4
Try warming also WD40 around joy stick base.
/ Loader Control Freezing #5
Could be this.
However, mine was freezing up at the spring inside the "can" on the valve body itself (opposite side of the valve from where the cable enters). I'd take a blow dryer or torch and hit the can and be good to go.
Finally one day I took off the can and a few tablespoons of water ran out, it's never froze since. I learned that my FEL control valves where made in Brazil, I'm guessing humid jungle air was sealed in there on the day it was made and condensed up here in the north.
I though about drilling a weep hole in the cover, but seeing how my FEL valves are located under the operator's floor, I reserved the right to sink the tractor in mud and water to this level. :eek:
Have someone move the joystick and look for movement down the line to the valve. You should be able to see what wiggles and what is frozen (either the stick, the cable, or the valve).
/ Loader Control Freezing #6
The latch to my dog's kennel outside was always sticking in the freezing weather. I had a spray can of John Deere lube for the shaft of my snow blower and used some of that. Hasn't stuck yet. The spray when applied looks weird; it like sizzles/atomizes on the metal.
/ Loader Control Freezing #7
One of my loader control cables freezes up in the cold, hit it with the propane torch and everything is fine until is refreezes.
I need to pull one end off and let the water out!
SR
/ Loader Control Freezing #8
Spray WD40 In those cables, it will flush out the water.
FIFTH WHEEL ATTACHMENT PLATE (A60736)
FIFTH WHEEL...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
43018CFL (A59228)
43018CFL (A59228)
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
