What is the next best 3/4 plywood when I can't get marine plywood?
   / What is the next best 3/4 plywood when I can't get marine plywood? #11
I had a couple of leftover sheets of 'exposure' grade plywood- intended to survive a limited time exposed before becoming the interior of a house. I used it in an exterior application, thoroughly primed with oil base primer then latex top coat. So far its holding up fine.
For a trailer that isn't left outdoors all the time I expect this would be ok.
   / What is the next best 3/4 plywood when I can't get marine plywood? #12
Have you checked to see if the lumber yards or box stores can order it for you? Menards carries 3/4" marine grade plywood in stock by us ($60 range) but I know there are no Menards close to you. It sure seems like the other box stores could order it for you at a reasonable cost.
Tried that several times, apparently if it's less than a truckload it's not worth their effort.
   / What is the next best 3/4 plywood when I can't get marine plywood? #14
When we lived in that area I used to get stuff at Barron's. It is a real lumber store, much better quality and selection than the homeowner places. I just checked their website, they have MDO plywood in 3/8, 1/2, and 3/4 sizes.
   / What is the next best 3/4 plywood when I can't get marine plywood? #15
Get a good sheet of plywood for cabinets. It will be great quality. It will not be rated for outside use, but with a couple coats of good paint, it will last forever. I drive by some every day that has been up for more than 30 years.
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A55302)
2012 New Holland...
2015 Cheverolet Tahoe SUV (A55853)
2015 Cheverolet...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
