blakester
- Joined
- Jun 11, 2013
- Messages
- 114
Hello everyone, have a couple questions about a winch lift i'm building. Ok first off ill describe the use and build. We have a small barn with a lofted area that we cant put any stairs up to due to space constraints. I want to put some things up top for storage, but much of it is too cumbersome or heavy to climb up a ladder with. I would say that the a heavy load would be 300 pounds, so not that much. I had a 3800 pound winch i wasn't using, so i Thought I would turn it into a lift to bring that stuff up and down. I built a small platform on wheels, 30"x27-1/2" out of 2x6. I ran 4 chains through a hole in the wood on each corner and double 1/4" x 2.5" lag bolted it to the underside. The winch is mounted on double 2x6s that span 5 of the 2x8 roof joists with 4 - 5/8" thick bolts that run through both 2x6's and have a nice wide thick washer on the back. Those 2x6's are lag bolted to the roof with 3 per joist. I pre drilled the roof joists, and slightly offset each lag to try to prevent splitting them. The roof is 40 years old and the wood has hardened since it was put in, and is in great shape. I have some pictures attached, the first try had the cross installed to try to keep the chains straight on the sides as high as possible. That image had me just slide it in there for reference, it was much higher before. I had them so high that they nearly went 90 deg to the hook. It was incredibly unstable and i think maybe i need more of the angle like in the image without the cross in it. That's question number one, what's the best way to keep those chains straight as much as possible. question 2 any one hazard a guess how much that setup would reasonable hold?
