New L3301 - Found an loose, extra bolt
   / New L3301 - Found an loose, extra bolt #1
12BravoEng
Black Forest, Colorado Springs, Colorado
Maybe Kubota L3301?
Yesterday, I dropped my keys from the ignition on my 3301. They fell though a crack in the floorboard and landed on a ledge underneath the tractor. There, I also found this sizable bolt. I've looked all over for a corresponding hole, but can't seem to find one. It might be an extra that was replaced during assembly, but it is a little disconcerting.... Thoughts?
   / New L3301 - Found an loose, extra bolt #2
It's hard to tell, but it looks like it was never tightened/used. Don't see any wrench marks on it.
   / New L3301 - Found an loose, extra bolt #3
Looks similar to one of the bolts that holds the bottom 3pt link pins into the transmission housing.
   / New L3301 - Found an loose, extra bolt #4
View attachment 534023View attachment 534024
Climb all over and under that new machine and check all your bolts. You know somebody at the dealership forgot to tighten at least ONE bolt, and there's a chance you are going to find more.
Nothing instills dealer confidence like finding loose/missing bolts on a brand new machine.
   / New L3301 - Found an loose, extra bolt #5
Looks like one of the sheet metal retaining blots, maybe the transmission cover.
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
