Adding loader 2010 5055e
/ Adding loader 2010 5055e #1
schoolsout
Awendaw, SC
Massey Ferguson 1533
May have opp to pick up a 2010 (IIRC) 5055e mfwd with no more than 200 hours and most of that is from mowing around house so not much abuse at all. Owner just bought a new one with loader/grapple instead of adding what he would have needed.
Owner is friend of family and we can get tractor for $10k or so, but wondering what a good ballpark figure would be for adding loader. I haven稚 seen tractor in a while, but I知 guessing no mid/rear valves so would need to figure in everything needed. Don稚 think we would need labor cost, but interested in pricing with and without 3rd function.
We currently have a MF 1533 with 4n1 bucket that works well so if cost for 3rd on the Deere is a good bit more, we would probably forego that option.
Any ideas out there? Just ballparking for now. Really want a little larger tractor to pull larger disk and other implements on occasion.
/ Adding loader 2010 5055e #2
non self leveling loader less any hydraulics or controls about 7k. You are probably better served to take the s/n of tractor to a dealer and have them quote hydraulics and controls depending on tractor set up it can easily be as much as the loader. The pricing of a non loader ready tractor is usually pretty enticing up until you learn what the price difference is to make them loader ready.
That's my fear. Thought a decent price on the tractor would make this doable. Good advice on taking s/n to dealer and inquiring.
/ Adding loader 2010 5055e #4
At-least it is a late model tractor and all of the kits can still be had, if you wait until the bundles are not available any longer then it gets much much worse. Another thing to think about is deciding up front on 3rd function hydraulics. On some of the simpler tractors when converting a two function loader control to a 3 function loader control in many cases requires removing a perfectly good 2 function valve, tossing it in the corner of the garage, and purchasing a 3 function valve (I could be wrong). So if you go ahead you will want to decide on that up front instead of upgrading later. Good luck.
/ Adding loader 2010 5055e #5
If you’re just wanting to pull a bigger disc and impliments leave the loader duty to the other tractor. 10k for a mfwd 55hp with 200hrs is a pretty solid deal. I “think” they came standard with the loader control and hydraulic ran. You’d need the loader brackets and loader. Might get lucky and find an nos 553 at a dealer too
Brett
/ Adding loader 2010 5055e #6
The cheapest way to add a loader is to sell the tractor without a loader and buy a new tractor with loader as part of options. Your family friend found this out.
Brett
Yea...a thought of ours. Would probably need to get weights up front, but that is minimal $$$, really. Just need to decide if just using this guy for pulling implements is a route that would benefit us over paying a little more money for an older tractor with higher hours, but with FEL.
Quit harshing my mellow! lol
I'll say this, though...the friend is the type that wakes up one day, decides he wants a tractor and owns one before the day is over...then mulls over that decision for the next year of his life. He's not hurting for money, but doesn't really research much before he pulls the trigger. With that said, I do think adding the FEL may be cost prohibitive. I think they put a $13k trade number on his tractor, but he didn't trade it and will give us first refusal (and he tends to come down on price for his buddies :) ) Our last few implements came from him and those were a 60" Befco tiller, 60" Caroni (I think) finish mower and some other item that I don't think we've used for $500.
/ Adding loader 2010 5055e #8
I recently looked at a used 5055e at a local dealer it came without a loader. Dealer quoted me $6500 turn key to instant a 210 loader.
So if I could find a 5055e for $10,000 and have $6500 in the loader that痴 significantly cheaper prices that im finding in my area.
Good luck.
/ Adding loader 2010 5055e #9
Brett
All the 5055E sold had the loader valve/joystick kit standard, at least when I was looking at buying one of those 3 or 4 years ago.
10 k is a deal. Sure you could get a brand new loader for $6k mounts/arms/bucket $16k cheap for a basically brand new tractor....
Haven't done anything yet. Buddy has figured out it is nice to leave bushhog hooked up to. We've got first refusal so just depends on when he wants to make a move. I think we will probably get it as we are about to do some thinning (pine) on 60ish acres and clear just a little more land to play with.
/ Adding loader 2010 5055e #11
Good luck.
That is not the case, mid mount valves and the controls are not a base feature for this tractor, it's not a lot only about $1,200 for factory install but for the price only shopper $1,200 is a lot. It is almost never the same amount to field install components as it is for factory installed components. Always be very careful when buying any tractor that you can not 100% verify that it is loader ready, as there is most likely a reason that the pricing is intriguing. Now the e series is a relatively basic tractor so the pricing is not going to be terribly out of wack, it's not until you get into high end ag tractors that the pricing gets downright crazy to re-configure after the fact.
/ Adding loader 2010 5055e #12
MFWD and loader joystick were standard on the 5045E and 5055E and optional on 5065E and 5075E, at least when I built online, shopped in person with Deere for the Tier II tractors (Flat top fenders), which a 2010 should be. This likely changed when the Pollution garbage models (round fenders) came out. I actually looked at buying a used loaderless 5055E with 100 hours in it, had the unused loader joystick on it, as did every single 5055E I saw. Was just a case of buying the 553 loader and brackets and bolting it right up.
Well, the buddy that we were going to buy the tractor from just bought a 5115 (I think) and is selling us his 2017 5065e with grapple and 8' disk for $22k. Not sure of hours, but I'd imagine it is around 100 or so. Too good of a deal to pass up. Hope to get it delivered from his farm to ours this week and put it to use next weekend. Going to be a step up from our Massey 1533...lol
/ Adding loader 2010 5055e #14
Good luck, hardly any hours on it! Seems like a deal with all the stuff with it.
Our current tractor has R4 tires and I thought this one had R1, but shouldn't be an issue. Have never had an issue with the MF in our sandy soil other than going back in woods where I shouldn't have been after a good rain and the bushhog caught on a root and I got the tractor stuck. R1s would have probably made it out, IMO, but we did sink down to the chassis after trying to get out under tractor's own power. Here's a pic of the tractor...not sure if we will be able to get it to our place this week, though.
2015 International PayStar 5900i 24ft. Flatbed Truck (A64194)
2015 International...
2019 Kubota L2501D 4x4 Utility Tractor with Land Pride 72in Brush Cutter (A64553)
2019 Kubota L2501D...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
2008 Toro Workman Utility Cart (A64553)
2008 Toro Workman...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
