Loader Bucket pin came loose
/ Bucket pin came loose #1
tman1020
north west indiana
Bobcat ct225 and Bad Boy zero turn
Was doing some loader work last couple days and some how one-of the bolt that keeps the bucket quick attach pins in is gone. I noticed the bucket seemed to have to much slop so I got out to take a look.
The pin had slid almost all the way out and had bent the bracket and no longer was engaged. Couple solid smacks with a 4# sledge and a little playing with the joystick it’s back in place and secure.
So keep a eye on your pin bolts and keep everything greased.
/ Bucket pin came loose #2
Totally serious possibility there. Glad it was not. I liked bolts with double nuts or lock nuts on there if possible.
I think I’ll pick up some nylon insert locknuts for it
/ Bucket pin came loose #4
Is there a chance to take a photo of the pin. For some reason I cant picture it in my mind. Any help would be appreciated
Sure I’ll take a picture but I fixed it now
Here is a picture of the bolt that is a keeper for the bucket pen
(1) UNUSED 31X13.50-15 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED...
L Shaped Transfer Tank (A64119)
L Shaped Transfer...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A61574)
2005 Freightliner...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
KUBOTA DM5032 HAY BINE (A64280)
KUBOTA DM5032 HAY...
