Bought a Case VAI-W Military Aircraft Tug!
   / Bought a Case VAI-W Military Aircraft Tug! #1
Pennington, NJ
Yanmar 336D
So a friend of mine went to buy a snowplow from a guy he found online, while at the guys farm he saw what turned out to be a 1945 Case VAI-W tug. My friend took a picture and called me, he even negotiated a price with the guy before I even committed to buying it! An aircraft tug isn't necessarily something I typically would buy but being ex military and extremely unique I couldnt pass it up. The next day we went and picked it up, this thing is HEAVYYYYYYYY and the rear fenders are SOLID cast iron! The engine was stuck but the previous owner said it was running when parked and he kept it inside his MASSIVE shop for the last 5 years. He said he put Marvel Mystery oil in the cylinders to hopefully unstick them. A handshake along with $300 and she was sitting in front of my shop. I filled the cylinders with a mix of 50% ATF and 50% acetone, let it soak for a few hours then started to work the flywheel teeth with a pry bar. After slowly working her over a few times put the starter back in with some fresh fuel and she roared alive! Surprisingly runs GREAT for not cleaning the carb or anything! So now the questions, how do I confirm the year of this thing? The serial tag that is supposed to be on the dash is missing. There is a tag on the hood that says USN and has a few numbers so it looks to have been used by the navy, is there any way to somehow trace this number to find its origin? On some spots the yellow paint is wore off and it appears to have OD green paint under it, I know this isnt the primer because I can see the primer layer as well. Is it possible it was OD green before yellow? If so I would like to restore it back to OD green.
20171204_142540.jpg20171204_142547.jpg20171204_142638.jpg20171204_142506.jpg20171204_142523.jpg20171204_142628.jpg
I absolutely love crawlers and would love to own a Cletrak M2 one day! That picture is very close to the look I am going for!
   / Bought a Case VAI-W Military Aircraft Tug! #4
That is pretty cool.
   / Bought a Case VAI-W Military Aircraft Tug! #6
It's unique for sure!!!
   / Bought a Case VAI-W Military Aircraft Tug! #7
I'd put wheelie bars on the back!
Now all you need is de plane!
Cool!
   / Bought a Case VAI-W Military Aircraft Tug! #8
That brings back memories from when I worked at airports about 30 years ago. We had a similar one. When the engine died, we wedged in a Chevy 350 with a TH350 tranny, and a tilt wheel from an Olds. :laughing:
For fun, see if you can figure out the rear axle ratio. Ours was something stupid like 27:1. :eek:
Neat find! :thumbsup:
   / Bought a Case VAI-W Military Aircraft Tug! #9
Better stay on hard ground.
ROADHOG CP24 SKID STEER HYD COLD PLANER (A54756)
ROADHOG CP24 SKID...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54756)
(2) CAM2 HI TEMP...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
