Review of chainsaw sharpener I just bought
   / Review of chainsaw sharpener I just bought #31
It shouldn't take 30 minutes to take a chain off and put it back on.
I saw clip of a competition. Total change over in less than 10 seconds. For me a minute or two depending on how long it takes to untangle the new chain.
I don't know how the dealers do it or what the look for but they will take a knotted chain, lay it on the counter, look at it a few seconds, pick up and it magically uncoils.
   / Review of chainsaw sharpener I just bought #32
My first requirement for buying any chainsaw chain sharpener is the chain stays on the bar, and the bar stays on the saw, the Grandberg meets those requirements.
The last thing I want to do is fiddle faddle around with taking a saw chain off the bar, whoops dropped it, now it's knotted all up in a figure 8, finally got the 20" chain unknotted so I can line it all up on a bench mounted chain sharpener.
Then have to fire up the compressor spend 15 minutes blowing the debris debree off the saw, line up the bar and chain with the rim sprocket, loosen up the chain tensioner, get the cover plate back, now where'd that nut go, tighten everything back up, twice, to me for me that's a 1/2 hour of complete wastes of time and unneeded aggravation...........
It's good practice to flip the bar over every other sharpening etc...
   / Review of chainsaw sharpener I just bought #33
It seems every chain I touch gets knotted somehow, and I can never figure out how to unknot them but somehow out of the blue they straighten themselves out. Go figure.
   / Review of chainsaw sharpener I just bought #34
No offense to anyone...but there is an old joke about tangled chains..."You have to be smarter than the chain"
   / Review of chainsaw sharpener I just bought #35
You don't need to throw away a chain that has stretched too far to tighten. Just remove (or have dealer remove) one drive link.
I've never had that happen, but I don't know why you'd go through that much trouble. A new chain is around $20 and the stretched chain is probably near the end of its useful life anyway. And it's nice to have a junk chain around for times when hitting metal is likely.
   / Review of chainsaw sharpener I just bought #36
Yep, not that hard. Drive links in and cutter teeth out.
   / Review of chainsaw sharpener I just bought #37
I put together a short video that I thought was short, but after uploading it I should've shorten it a little more. I been using my sons Stihl 441 Mag with 20' with bar the last few weeks and after a final bang on a rock it needed sharpening bad.
So this afternoon I went to get it back to full chisel, started with a new flat file, went around the worst side with 7 swipes/tooth ended up ruining the file, I wanted to do both sides but I dont know what that chain is but if it was any harder it would be carbide. Then I put my Granberg sharpener on it and even that had a tuff time compared the the Oregon chains I get, so after I went around the chain then look it over with flashlight, nope needs one more time, then check it again, nope this chain is so hard I had to go around it three times, thats the video I made of this one last time, just a little more touch up. Think I was about a hour trying to straighten that chain out, the good news is the saw didn't have a 24" blade on it.
Should've had my son videoing so could zoom in better but after church all he does is nap all afternoon. So if you got a few minutes to waste take a look and maybe get idea of how a Granberg sharpener works. I didn't up load the whole video if I did be hour long, I also left out taking the rakers down with it, maybe next time. If my son trys his saw out this week he better hang on.
IMG-2015.JPG Chainsaw sharpening - YouTube
   / Review of chainsaw sharpener I just bought #38
I used a friend's power sharpener once and it hardened the teeth so much that I couldn't use a file on them anymore. Is that what your son uses for sharpening?
   / Review of chainsaw sharpener I just bought #39
No he uses a file, I tried it and his file was dual, he said it wasn't that old, they dont last long on a Stihl chain, and that chain was the first time the Granberg sharpener was on it. I've been using my Granberg sharpener now for 2 years on my saw with 325 Oregon chains, they sharpen easier, maybe Stihl makes a stronger file for their chains. As hard as they sharpen dont know if I'd wanna put one on my saw that I havent bought yet.
2021 Deere 333G (A53317)
2021 Deere 333G...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
Ez-Go Electric Cart (A55853)
Ez-Go Electric...
2003 SHOPMADE GOOSENECK CASING DRILL PIPE HANDLER TRL (A55745)
2003 SHOPMADE...
Scissor Lift (A55973)
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
