Tiller How big should I go? Topic is 3 pt Rototillers.........
   / How big should I go? Topic is 3 pt Rototillers.........
Appreciate all the replies, suggestions and advice. Will check out as much as I can.
My BIL just offered to loan me his 5 foot tiller on a long term loan basis. He said that it is actually a 4 foot tiller with 6 inch extensions on each side. Suggested we take off the extensions. Sounds like a plan with one problem. I don't borrow equipment. I think it is an option but, only if he'll sell it to me. Things that get borrowed always seem to get broke and I hate having to fix or buy parts that aren't for my machines. I always return things I've used in as good as or better condition than when I borrowed it. That can get expensive. It is, what it is.
   / How big should I go? Topic is 3 pt Rototillers......... #22
That is hard to do - on both ends. Friend passed away and widow does not know who had what. I am going to walk away. Will never lend or borrow again.
Here is a great price on a brand new, quality italian made Caroni tiller that is 43" wide, which would be perfect for your tractor: Year-end Auction! Caroni 43" Heavy Duty Rotary Tiller/Compact Tractors,15-3 HP | eBay You will never regret buying quality.
That looks like a perfect tiller for my Ford 1210 at a decent price but......................
I'm having a hard time not offering my BIL the few hundred bucks he's told me he'd take for his 5 foot tiller if I can remove the two 6" extensions (which will make if 48" in width). That's a few inches wider than my tractor but, I have to assume I could always remove a few tines to get where I want or need to be.
Rams
Yeah, I have five different trailers (three goosenecks). People (friends) are always trying to borrow the bumper pulls (most of them can't pull a gooseneck). It's hard to make them understand that I won't take any excuses for bringing back a borrowed trailer that isn't as good as it was when I loaned it out. That's not to say I don't have a few trusted friends that I wouldn't let my wife go out for an evening with or loan a trailer to but, my trailers don't have a choice about what's about to happen to them. The trailers don't get loaned out much cause I don't trust many folks to take care of my equipment the way I do.
The wife, she demands first rate treatment. ;)
   / How big should I go? Topic is 3 pt Rototillers......... #25
I have a Ford 1210 three cylinder diesel, hydrostatic 4wd drive, turf tires. If I remember correctly, it's 16 horse.
Have been looking for a rototiller for my hobby passion. Have found a bunch but, most are much bigger than I think my little tractor can handle. I'm thinking 36" to 42" width at maximum. Appreciate any thoughts or advice on this. The last thing I want to do is go too big and have a tiller that I can't use.
Thanks in advance.
Rams
I run a 6' on a 38 hp tractor not because of the load but because you can only go so fast in hard clay. I have 9 beaters and 6 blades per for 54. Half that is 27/6 per = about 5ea 6 blade beaters or for the cheaper/light duty models 27/4 per = 7 ea 4 blade beaters. Weight is not a problem as a function of width for 3 pts. to lift.
That should give you an idea as to where to start thinking about size in my estimation.
   / How big should I go? Topic is 3 pt Rototillers......... #26
What is a "beater", never heard of those on a tiller...
SR
   / How big should I go? Topic is 3 pt Rototillers......... #27
SR
Slang for a device to which the tines are attached, driven by a shaft. What do you call it a digger hootus?
Well, I used to call her Stacey............. But, that was before the divorce............... ;)
   / How big should I go? Topic is 3 pt Rototillers......... #29
I call it by the name the tiller mfg's use, "flange"...
The tines are bolted to flanges...
The part of Texas I was in last time I was there, they still spoke English...
SR
   / How big should I go? Topic is 3 pt Rototillers......... #30
I have a 40 Hp tractor and a 72 inch tiller so it cover the tire tracks. You definitely want the tiller at least at wide as the tire tracks.
I've never felt the tiller ever came remotely close to bogging down the tractor, so it is probably more about the weight your tractor can handle on the 3PH and still have good steering control. My tractor is 4WD so that helps with control too.
I till one pass in the lowest or second lowest gear at a little less than the rated 540 PTO speed. Then if needed, the next day or at least a few hours later a second pass at right angle to the first in the next one or two gears higher is plenty.
Sod is more difficult. I generally prefer to turn sod with a plow first and then 2 passes with the tiller.
Others are right to go as quickly as works the ground and do not turn it to powder. Adding organic matter (manure, leaves, etc.) is the best thing you can do to improve your soil and you will need less tillage to keep it loose. The next best is to plant cover crops to add organic matter.
8' SMALL FENCE POSTS (APPROX. 40-50 PC) (A54757)
8' SMALL FENCE...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
SOMERO S-222 LASER SCREED (A52707)
SOMERO S-222 LASER...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
2013 Case TR270 Compact Track Loader (A55314)
2013 Case TR270...
