   / Your last generator Maintenance Run
i dont know if they ever actually issued a recall or not. that was before my time working on them. ive only witnessed a few myself. if the owners kept up the electrolyte levels there was no issue. heck, i even check mine yearly just to be sure.
i went 19 years having a manual start unit. i only switched out to the 22 kw fully automatic unit a little over a year ago. after two years of 3-5 days without power, enough was enough.
the new units power my entire house and the barn. the horse waterers wont freeze now. i put a portable interlock device on my shop cause i couldnt open my roll up door last time power failed. i have a few portable generators laying around.
when we had the 5 day outage, i loaned them out to neighbors. it still amazes me that most of my neighbors dont even have a 2000 watt gen available. all they like to do is sit in the dark i guess:cool2:
ShoeMakers Children :D - good to see you that caught up with your clients :thumbsup: Auto-xfer is nice; I remember your post about doing some ledger work on your computer at home, and not even realizing the generator had taken over.
To your last point, some people never plan ahead, or for emergencies. I've seen some extended outages in urban areas at times, but in many rural areas you can expect long outages.
Some people have trouble keeping lawn mowers going season to season - at least up here where they sit idle a good portion of the year. I suspect some people may have given up on portable generators, after trying one once, then letting it sit with old gas in it for way too long.
For some households, if you're not into basic generator maintenance, then a 1kw+ inverter might be a good choice if you can park a vehicle near where you need power.
Rgds, D.
   / Your last generator Maintenance Run #1,272
generac offers oil filter and battery heaters...and a breather tube heater for super cold climates. there about 80-90 each. worth their weight in gold.. i can tell the difference in how the generators sounds on cold day startups. the units sound way happier.
Amazon.com : GENERAC POWER SYSTEMS 71�2 9-22KW Oil Heater Kit : Garden & Outdoor
thanks, think I'm going to invest in one of these. Where does it plug in for power? Would be nice to have a dedicated connector with thermostat. ........
   / Your last generator Maintenance Run #1,274
The "blister" on the wire between the heater and the plug looks like a thermostat to me.
DEWFPO
Agreed. The gen controller needs to be fed utility line-power - that connector likely has a mate on the factory board, that feeds utility line power to it. My guess, anyway.....
Rgds, D.
   / Your last generator Maintenance Run #1,276
Amazon.com : GENERAC POWER SYSTEMS 71�2 9-22KW Oil Heater Kit : Garden & Outdoorj
they get power from the n1 and n2 circuits on control circuits. These are the circuits that are hooked up to the fuses in transfer swircg. The circuits are already present in the generator ... at least in the 2008 and newer units. Some of the older ones need additional circuits run for heater. They have built in thermostat.
You can order them thru lowes and home depot also. Parts # 7101 and 7102. About 70 bucke each part. Takes a few minutes to install
   / Your last generator Maintenance Run #1,277
Rgds, D.
good guess. Its fed from n1 and n2 utility feed lines
Nice setup on the newer ones - plug and play heat, only when needed. Do you install those pads with thermal compound (grease), or dry ?
Seems like a good idea, at least for any area that sees low temperatures like we do - to daugen's point, not many other applications have to come up to high revs immediately in cold temperatures, like generators do.....
Rgds, D.
   / Your last generator Maintenance Run #1,280
The gensets on the job simply scream... start, full throttle and transfer load average of 6 seconds... must complete by 10 seconds to meet Hospital Standard.
I keep coolant heaters plugged in 24-7 and they cycle on and off as needed... jacket temp is 155 to 165 F
Engines are turbo Cummins Diesel...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
Hose Reel (A53424)
Hose Reel (A53424)
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2012 Club Car Carryall 1 Utility Cart (A55851)
2012 Club Car...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
