I want to install a whole humidifier
   / I want to install a whole humidifier #11
Have you looked at the Aprilaire 800 steam humidifier? Different install arrangement which may work better for you -- just put a steam nozzle into the supply duct downstream of the furnace and the humidifier unit can mount off to the side on a wall in the room.
I did, but they are around $700.
   / I want to install a whole humidifier #13
How many sqft is the house? The 600 is a good unit for <2000 sqft. More than that I'd look at the 800 steam.
   / I want to install a whole humidifier #14
We didn't have one for the upstairs of our house. The circulator is in the attic where water for a humidifier would freeze. So, we put a Honeywell Truesteam unit in a closet in our master bath room. It's just on about the 3rd shelf in there. The wife has sheets stacked on the rest of the shelf. We had a few problems with it until one of the technicians found the steam line wasn't completely straight, e.g. had some very slight sags in it. After the sags were removed, it has been troublefree. Just needs cleaning, which is easy to do, about every 2-3 months in the winter.
Another really old humidifier for the basement and 1st floor just sits below one of the air ciculator ducts. Don't recall what the manufacturer of it is but certainly does not require much space. It's a Skuttle. Just checked.
On any humidifier, you want to have a regular dump of the water in there. Otherwise, stuff from your water will collect and really cause a cleanup problem. A dump gizmo was put on the old unit. The Honeywell has it built into the logic of the controller. Still, it needs cleanouts more frequently than the old unit that is just a water on/off valve with a ball float and an electric coil in there to boil the water. Quite simple.
Humidifiers can be controlled with a separate humidistat or can use the one on most modern thermostats. Our new one used to have its own controller, but they put it into the new thermostat when we had to replace the upstairs system.
Ralph
   / I want to install a whole humidifier #15
A bypass might be your best option. The supply connection can go anywhere on the supply side, but try to install it well before trunk T. If you get it too close to the T or after the T, you could run into moisture distribution issues where a portion of the house isn't seeing the moisture. Make sure you tap into soft water and I'd suggest using hot water. There are direct injection systems (steam or spray), but they seem to demand a higher level of maintenance.
Tapping into hot water is a good idea but do NOT use water softener treated water!
A bypass is the way to go...steam generators are expensive and require more maintenance and replacement of expensive parts on a more frequent basis.
A sheet metal shop can make a fitting to tab into the side of the return drop and flare out to the dimensions needed to mount the humidifier. You have enough room to tap into the left side of the plenum with a 6" round to feed the humidifier, a little aluminum flex will make that easier.
   / I want to install a whole humidifier #16
We've been running a steam unit (Aprilaire 800) for 5 years and haven't had any issues at all. Prior to installing a water softener, I was replacing the steam canister annually at a cost of $55. Since installing a water softener, I have been stretching canister replacement to 2-years, so figure $28/year. The steam units cost more up front, but I like the performance much better than the bypass system we had at our previous house.
My house is about 1500 SF. I'm looking now at the Aprilaire either the 500 or the 500M. I have to install the unit on the return line. Aprilaire, in their directions is saying that the 500 (non manual) needs to be connected to the hot water line. I don't have that option. I just replace my tank hot water heater with a tankless, so I cannot connect it to the hot water side. The Manual one it doesn't specify hot or cold.
   / I want to install a whole humidifier #18
I've installed and serviced hundreds of humidifiers and I'll stand by my statement that steam units will cost more to maintain than any bypass unit. A steam unit may benefit from softened water but a evaporative type will be caked in deposits in no time.
"My house is about 1500 SF. I'm looking now at the Aprilaire either the 500 or the 500M. I have to install the unit on the return line. Aprilaire, in their directions is saying that the 500 (non manual) needs to be connected to the hot water line. I don't have that option. I just replace my tank hot water heater with a tankless, so I cannot connect it to the hot water side. The Manual one it doesn't specify hot or cold."
You can still tap into a hot water line close to your heater or a hot line which is used often...it will provide enough hot water to make it preferable over a cold water line, even though the heater itself won't cycle.
   / I want to install a whole humidifier #19
In houses with traditional water heaters that have long runs to the furthest faucet, it is possible to install a crossover that allows you pull hot water from the tank (flowing back through the cold line) so as not to waste water down the drain while waiting for the hot to arrive.
Could a similar crossover be installed near the outlet/inlet of the tankless, triggered by a signal/relay from the humidifier, so that enough flow through the tankless to trigger heating occurs and thus providing nearly instant hot water to the humidifier feed line?
I could install a re circulation pump, but that concerns me that the tankless hot water heater would run more than it should. I also can't seem to find good information on one for a tankless water heater. Rheem makes one, but you have to have a return line from the furthest fixture which I don't have and would be to difficult to install one since the walls and ceiling in the basement are finished.
Portable Restroom (A54865)
Portable Restroom...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
UNUSED JCT HYD AUGER (A54757)
UNUSED JCT HYD...
(28) 4' FLOURESENT LIGHT CEILING FIXTURES (A54756)
(28) 4' FLOURESENT...
New Idea 310 1-Row Cornpicker (A50775)
New Idea 310 1-Row...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
