Smart battery chargers with reconditioning modes
   / Smart battery chargers with reconditioning modes #51
Amazon.com: CrazyEve 5 Sets 2 Pin Car Waterproof Electrical Connector Plug with Wire Electrical Cable Connector Plug: Automotive
I just got some of these in a few days ago to install LED lights on the small Massey. I really would like something heavy duty for these chargers, almost like a plug
in connector used for dockside power on a boat. I bet there are heavier duty versions of these plugs, only need two leads, but to carry 8 amps, maybe sized for 15?
I think I know enough to be dangerous here...but always want to prevent toasters, perhaps with an inline fuse.
these big chargers weren't cheap and I don't want to buy five more of them, this one is going to travel.
But clips are iffy and have exposed shortable connections if one is clumsy. Not us of course.
I would use a 2 pin plug such as Amazon.com: CES 1 Gauge 2 Pin Quick Disconnect Harness: Automotive or Amazon.com: Tetra-Teknica MotoBasics Series RHS-1 12V Ring Terminal Harness with Black Fused 2-Pin Quick Disconnect Plug, 2 Feet, 16 Gauge Copper Wire, 1A Fuse, 2 Per Pack: Automotive (includes a fuse).
That should be good for a charger, your sprayer pump or some lights, not big enough to start something though.
Aaron Z
   / Smart battery chargers with reconditioning modes #52
Aaron Z
Don't buy that first one you linked to. I bought some of these (there are many similar others too) and they are very poor quality and do not connect to each other without distorting the pins. I learned my lesson.
I have many of the pigtails from BatteryMinder or BatteryTender brands. Maybe some Schumacher too. They are all very similar to each other and good quality.
   / Smart battery chargers with reconditioning modes #53
I'm thinking of adding one of these bulkhead fitting charger connectors to a couple of my "toys":
Flush Mount EZ Connector
Flush Mount EZ Connector with ring terminal and fuse
Just haven't figured out where I want to mount the one on my tractor
   / Smart battery chargers with reconditioning modes #55
I’ve had good service from the three Battery Minder Plus chargers we have.
https://www.northerntool.com/shop/tools/product_200332201_200332201
That model (12117)has been discontinued by VDC, the folks who make the BatteryMinder chargers (I'm guessing Northern Tool bought out their stock, since they were discontinued a while ago, but NT still has them). They are still good battery maintainers. I have one that has to be more than 12 years old, and is still going strong.
It was replaced by the model 1500 (model 1510 is electrically identical to the 1500, just has 10 year warranty instead of 5, and comes with insulated battery clips). The 1500/1510 adds the ability to recover batteries which are much more deeply discharged (down to about 3 volts, if I recall), along with a couple more stages in the charging process and temperature compensation.
They also make some higher amperage chargers, but the price jumps up significantly for those.
   / Smart battery chargers with reconditioning modes #56
Here are 3 of my 4, and they vary quite in 'buttons and bows'. First, 'Accumate' apparently uses an iron core power supply like our 'dumb' chargers vs 'switching' type of 'BatteryMINDer' and what charges our handhelds. I kinda doubt that this aspect is as significant as the electronics and automation within, and if the 'PT Xtreme' is by far the largest it weighs about half as much as the Accumate.
I've braced up tired batteries that had to be topped up every 4-5 days, and with auto/float gear, to light their fires. After playing back forth with 'AM' & the 'B's, I just won't accept these as 'snake oil', and based on some batteries' seeming stronger if floated, and faded less during idle periods after. btw, I'm darn sure I haven't used both brands on any battery (autism :rolleyes:), so I'm happy to put my personal stamp of 'maybe you care' on 'em. :thumbsup:
I wish I could offer say, a controlled test of the now-three chargers, or monitor results with an o'scope to see what's really 'what' when one is OTJ. However, and unfortunately, the matrix of procedures would exceed the capacity of any lined paper I have on hand. Sorry :D That said, I could set up just about anything y'all suggest with the Pulse-Tech Xtreme that just came today (also means I'm adrift on where to re-connect which one next .. :confused2: ... old age .. :laughing:)
EDIT: Ultrarunner, please note that 'Accumate' 'does 6v'. It did a J.O.B on a 280CCA that wouldn't start w/o a jump (B&S 22hp). I did it 'the long way' for lack of confidence by disconnecting sometime after 'green', and reconnecting 24 hrs later. The first few days it was 18 hrs to 'go green', after a week maybe an hour or two. Yes, it was 10 days or so when the light would turn green inside of a minute. No guess whether I needed to disconnect daily, but falling on my old practice of soaks between cycles I hope it suggests that desulfating was at least as much the boost as depth of charge would be. My point is that the IMO Accumate shouldn't disappoint in 6v mode. :)
   / Smart battery chargers with reconditioning modes #57
I am constantly connecting my smart charger to my home made water wagon. Have planted hundreds of trees and shrubs and this cart
has been my savior. I can sit on my comfortable garden tractor seat and water; no more lugging water hoses and cans.
While I regularly use my larger charger on just two devices, this old tractor battery in my water wagon, and an equally old set of batteries
alongside my diesel tank for the 12VDC pump, an IDI. I'd love to rig up something where I don't have to use alligator clips on batteries. I did replace
my clips with better quality aftermarket alligator clips, bigger, sort of Good Grips clips. But there has to be a better connector for constant
connections, and having owned a Radio Shack for five years, I can think of a few. I have bad arthritis so I really do need something easy to handle, which is not your
normal issue I realize.
I can go three barrels, sometimes four before the pump starts to slow down. That's usually long after I have slowed down even more...
Without constant use of these smart chargers, I think I would have been buying new batteries long ago. But so far, the ones I've recycled, usually after five or seven years in something
else, are going strong in their second life.
I have envisioned designing a better water wagon, with a horizontal tank for lower CG. This thing has wanted to turn over on me a few times, but I have it strapped and the
JD cart is rated for 300 pounds more so it has worked so far. Just have to be careful near ditches, otherwise everything is flat as can be here.
Back on topic, my charger has options of 2, 4 and 8 amps. Are there pros and cons to these settings beyond the obvious time savings?
I sure don't use the 8amp setting when I charge the tiny little battery in my DR Rotohog tiller...I'd be afraid it would blow up.
Though I doubt it would, it would reach the proper voltage and the charger should turn off, or way way down. And do so intelligently.
Something lacking for sure in the old battery boilers.
btw, these alligator clips in pic got replaced with bigger ones.
Just guessing - probably your arthritis will be the gating factor re. the best connector choice.
Flat 4 trailer connectors are cheap and widely available. Could be doubled up (2 pins per conductor) to handle more current on a 2 wire hookup. For pulling apart, maybe drill a hole towards the back of the body of each connector, and loop a zip tie through to make an easy pull ?
For custom wiring, Anderson power pole connectors are more expensive, but are scalable to major current levels and are easy to configure in custom/keyed orientations (a bigger benefit with more complex hookups than 2 wire). Should be available various places online, or if you can still find an amateur-radio store standing (or get to a AR flea market), they should be on the shelf.
Powerpole(R) Stackable Connectors, Anderson Power Products
Kind of like Lego 101 for the connector world....
Rgds, D.
   / Smart battery chargers with reconditioning modes #58
Aaron Z
yes, thanks, this is heavier duty version. Dave's idea of doubling up on a trailer plug was a great solution for how can I do this with what I have.
something simple hanging down would be ok; thinking of the receptacle end. Dave, pushing the plug in isn't so bad. It's pulling it out that is hard. And why getting a PTO collar off is becoming a real issue for me.
   / Smart battery chargers with reconditioning modes #59
I have a Genius charger and wonder if I can battery recondition/desulphate in cooler weather? No mention in the manual. It's in the low 50's now and I wonder if too cold or if that even matters.
   / Smart battery chargers with reconditioning modes #60
Even a non-temperature compensated charger should handle the low 50s with no problem. THe recommended charging & float voltages for the low 50s only differs by 0.4 volts from what it would be for a temperature in the 70s.
Also: as the temperature gets colder, the recommended charge and float voltages go UP. So you won't fry a battery by charging it on a non-temperature compensated charger. The worst that will happen is you will not charge it fully (which is not great, but better than not charging it at all). I've attached the temperature compensation graph form one of my charger's manuals. (One of these days, I need to get someone to tell me how to attach a full-sized picture, rather than a thumbnail)
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
24in pin on tooth excavator bucket (A56438)
24in pin on tooth...
2020 CATERPILLAR D1 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2014 CATERPILLAR...
