Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #3,781
I have a plow I purchased from QuickAttach with wings that make it a snow pusher and just fold around the back for storage when not needed and I also have a grader blade for the rear and a 3 pt. sander that works great. P2100017 (2).JPGP2100018 (3).JPGP1260005 (4).JPGP1280013 (4).JPG
   / Pictures of your snow weapons #3,782
I doubt that will be much of a problem. The worst that will probably happen is a little bit of wet snow will pack in the gap, in effect filling it in so the snow that follows will slide on past.
This was my thought.
   / Pictures of your snow weapons #3,783
Man - when I had my 3-point blower I made a set of "wings". Crude & ugly would have been a very kind description. HOWEVER - they did work, even if I had to unbolt & remove, to straighten out, occasionally.
I think your fancy wings will work great and are the cats meow..............
   / Pictures of your snow weapons #3,784
Are these considered "snow weapons"? Maybe they are. Snow is my business.... Hope you like them. I should add, we do receive snow here.
How do you like the Defender?
   / Pictures of your snow weapons #3,785
   / Pictures of your snow weapons #3,786
i have the exact same plow. those blades work great
Great people at QuickAttach. I'm thinking of a 3 Pt. blower, but my 1000' gravel driveway is making me think hard if it will work well enough or just throw stones or break shear pins.
   / Pictures of your snow weapons #3,787
A properly set up and operated 3 pt blower should not be breaking shear bolts from some gravel. My 90" inverted blower was bought new in 2008 and still has the factory shear bolt as it has never broken. I have a long gravel driveway as well + clear about a kilometer of grass and ground walking trails thought the farm. When the ground is very soft, the blower throws sod with no problem
Don't be too influenced by the experiences of those with front mounted blowers as some of those implements are a bit fragile.
If you have some fabricating skills, you can add casters or wheels to keep the blower up just a little. The skid shoes don't seem to do the job when things are soft but it all depends upon many variables.
This is the ideal add on. The wheels are lower hydraulically.
Dave m7040
   / Pictures of your snow weapons #3,789
One of my favorite pictures. New Holland S-14.
   / Pictures of your snow weapons #3,790
Dave m7040
Thanks Dave, good info. That's a nice set-up, I like it. Maybe next year for the blower, this year it's too late and I'm sure the prices are premium.
pressure washer, and trailer (A56859)
pressure washer...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
set of 4 tractor trailer tires Roadforce (A56438)
set of 4 tractor...
