rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,198
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
40F and mostly cloudy but seeing an occasional peek of sun.
Actually seemed fairly pleasant when I was outside earlier.
Today will likely be spent working on repairing a friends old KK landscape rake. The pivot point - which he claimed was loose and flopping around - was made by using a piece of pipe that fits inside another piece of pipe. The first piece of pipe was welded to the frame that holds the tines ... and then had an index plate welded on top so it was "captured" and couldn't be disassembled without cutting it apart. Also not greasable ...
The pipe that the other pipe fits into had broken off the 3PH frame at least once, possibly twice. Previous repairs were not particularly impressive.
The angle that the tines attach to is only 1/4" and it's pretty bent up and has a couple of cracks in it where the reverse angle that forms a box is welded to it.
I've got some 2" CR solid and a piece of 2" DOM heavy wall tube that would make a nice pivot (what I used on my rake) ... the trick will be getting that welded on at the correct distance so that the index plate can be locked into it's bracket to hold the rake stationary.
Loads of fun ...
Loads of fun ...
