EMP Prep, What would you do if you had 45 minutes to prepare?
   / EMP Prep, What would you do if you had 45 minutes to prepare? #31
As far as EMP goes. I don't know enough about it. Would grounding circuits making a low resistance be better than leaving them open?
Any semiconductor junction outside a well designed shielded room (Faraday cage) will likely be blown. Grounding matters, but only accomplishes much if attached to said shielded room.
To 90s question - not much, as anything meaningful (obtain significant water, food, mechanical only equipment, tube operated electronics.....) would typically take much longer. I'd fill up as many vessels as I had with water, but that's probably it. (Yes, I realize civilians won't get the headsup in time...)
The EMP area would end up circa 1880, less telegraphs.
90 does have a point about prep though (often not easy to discuss publicly, w/o being labeled a wingnut though.....), as most of us take our modcons for granted. Another Carrington event will happen; it's just a matter of when.
Rgds, D.
   / EMP Prep, What would you do if you had 45 minutes to prepare? #32
Sorry Sig. Can't believe you believe that.
I do.
Know my neighbor pretty well who our road is named after, as well as his sons and grandkids (all relatively successful in their own right). Also know most everyone who lives on the road that doesn't have the same last name as well.
The reality is I coudn't move all my ammo in my truck if I wanted to, added, the best offense if you don't want losses is a good defense. Makes more sense for everyone to stick together and stay put. Build a good defense, and work on water a water supply.
One could argue even if you have the electronics background, all one needs to do is kill you for ALL of the snicker bar.
Don't get me wrong, I have no doubt there will be people only looking out for themselves.
God gave us a brain, lets hope we use it.
   / EMP Prep, What would you do if you had 45 minutes to prepare? #33
Alas Babylon?
David from jax
   / EMP Prep, What would you do if you had 45 minutes to prepare? #34
Not for long...under M.L. the constitution is suspended...guns would be confiscated...there would be zero tolerance by the military...
Without using Weapons of Mass Destruction, i.e., Artillery, Aerial bombing, Tanks, Bradley Fighting Vehicles, Apache Helicopters, Armed Drones, etc., etc., the military would be unable to disarm the citizens of this country. So then you have military personnel going AWOL by the thousands. In the end Anarchy would win......
   / EMP Prep, What would you do if you had 45 minutes to prepare? #35
   / EMP Prep, What would you do if you had 45 minutes to prepare? #36
Like I said...there would be zero tolerance...and just an opinion but I would think there would be masses wanting to enlist in the military rather than leaving...
   / EMP Prep, What would you do if you had 45 minutes to prepare? #37
I do.
My old, WW2 Ranger mentor once told me, " You never know what is cooking in someone else's pot "... Don't be surprised, in a true calamity, your neighbors aren't measuring you up for their pot.
   / EMP Prep, What would you do if you had 45 minutes to prepare? #38
Rgds, D.
Semiconductor junctions are far too small to develop a damaging voltage. The real threat would be from wildfires cause by arcing and falling power transmission lines, wire fences, or anything else long enough to collect inductive voltage. For EMP, the bigger the worse. Car computers might even be unaffected, depending on their orientation.
   / EMP Prep, What would you do if you had 45 minutes to prepare? #39
Well - if it were winter, like now, I have dry food for about four months. Water supply is forever. Firewood forever. After six months - I would simply die. Food would run out - since its winter, I can not grow any.....................
What difference does it make. The electric grid certainly will not be back up in six months or a year and without food we are gone.........
   / EMP Prep, What would you do if you had 45 minutes to prepare? #40
How long is a typical EMP event? Long enough to start fires? I would have thought milliseconds. Like I said, I don't know.
My hope is that I never live to see such a break down. If I do, I would consider myself lucky, if killed quite soon into the scenario for the Snickers Bar.
I heard stories about Katrina and cops stealing generators and booze, holding up in hotels basically looking after themselves, keeping others away from their little oasis. I think this is quite telling of human nature.
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
2006 MACK CV713 KILL TRUCK (A50854)
2006 MACK CV713...
2019 Dodge Journey SUV (A50324)
2019 Dodge Journey...
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
