Snow Rear 3PH Snowblower Re-Build and Conversion to Front End Loader Mount using Hydraulic
   / Rear 3PH Snowblower Re-Build and Conversion to Front End Loader Mount using Hydraulic #1
mikester
Elite Member
Canada
M59 TLB
'Tis the season to think of cleaning snow...
I just updated my blog on my experience converting a rear mounted 3PH Snowblower to work on a Front End Loader. I used a hydraulic motor to drive the snowblower's PTO. Part 2 shows my complete rebuild of an old 3PH Lucknow snowblower and conversion of the manual chute turner to hydraulic turning.
You can view Part 1 of the blog post here.
Please send me your comments!
I'm in the process of getting some more photos of the Quick Attach to 3PH Adapter Plate I made. If anyone is interested in any particular details let me know.
   / Rear 3PH Snowblower Re-Build and Conversion to Front End Loader Mount using Hydraulic #2
Nice setup. I saw the list of pros & cons at the end. So in the end was it worth all the labor & expense? Did you previously have a plow on the front & the blower on the rear? Or just the blower & bucket?
I just welded a QH to a SSQA plate to make my plow mount as well. Worked great & I ended up using it a lot for moving other impliments around & doing maintenance on them. Being able to pick up my flail or tiller & rotate them 90 degrees to work on the undercarriage is great.
I figured the $350 risk was worth it as I could still use the hydraulic motor elsewhere. I don't really count my time or the metal cost as my spare time is "free" ;-) and the metal for the 3PH to AQ adapter came out of my scrap bin. In all it worked out better than I expected. If I kept the smaller snow blower I would have kept using it on the front...which I did for about 5 seasons.
I don't use the 3PH to QA adapter currently and its collecting dust in the corner. I want to make a power rake setup so I'm hanging onto the adapter for now. I did re-purpose the hydraulic motor and hoses - I converted my 8" chinese chipper to hydraulic feed - worth every penny there!
Generally I leave a set of forks on the loader as I use those the most in winter for firewood etc. I don't use a plow because we get too much snow here.
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
Crate of Misc Lawn Equipment (A56469)
Crate of Misc Lawn...
2023 Air Chipping Hammers (A55851)
2023 Air Chipping...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A57193)
UNUSED WOLVERINE...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55973)
2012 Chevrolet...
